AVS › AVS Forum › Audio › DIY Speakers and Subs › Speaker Designing
Speaker Designing
post #1 of 9
Hello again all.
So, I have been experimenting with Speaker Workshop for a month now. I have the whole setup, W/JIG II, Mic with Phantom Power, and a USB Creative SB 24 Live hooked up to my HP lap top. This thing is kicking my butt. I finally got the volume to calibrate and I think the latency is set right. What a pain. Is there anything else to use in the place so SW? I sure like the idea of being able to measure the speaker in open air to get real data to build the cabinet and cross over based on what I find. Any suggestions?
post #2 of 9
Designing speakers takes skill and a lot of experience, which is why very few people, even in DIY do it.
post #3 of 9
The idea is not to measure the drivers in open air, you want to measure the drivers in the baffle where they will be operating. Then design the crossover based on the measured data.
SW isn't user friendly at all. There are no easy to use freeware programs that allow gating of the signal.
If you want to do a screen capture of the measurements, ETF 5.0 is more user friendly than SW. The demo doesn't allow saving of data but a screen print gets you a copy of the plot. Nice thing about the ETF demo is that you can get free tech support for it via the tollfree number on the website.
http://www.acoustisoft.com/
post #4 of 9
He isn't kidding. I'd hate to add up the hours I've spent learning, measuring and building. Its a deep subject that takes a multi-disciplinary knowledge base. You also need tools that have a learning curve and will spend a lot of time making bad speakers before you make good ones.
Some hints to get you on the way:
#1. Measure your drivers in the enclosure you are going to use them in. You should have a basic idea of how they are to be used from Manf. specs so build the enclosure. Do your measurements outdoors, with the enclosure about 8ft off the ground. I built a support for doing this so that I get good clean measurements. You have to start with good clean data to get good repeatable results.
#2. Measure FR for the drivers in the enclosure they are to be used in @ about 2M (more for something like a line array). Make sure your well into the far field of the loudspeaker. Set your levels and take one measurement, then swap to the other driver without moving the mic or changing levels. Take the second FR, if your doing a 3-way take the third driver FR measurement, etc....
#3. Measure the Z in the same set-up but obviously you can take your proto -box off the stand.
I also like to get off-axis measurements for the drivers while its in the same position. That way you can model the off-axis data with the real off-axis measurement. I can swap between measurement data with a given crossover and see how it looks with both the on/off axis measured data (the Z doesn't change ).
Then you build something and re-measure to see how close you are to the model. Then you start the listening process to "voice" it to taste. I re-measure multiple times in the voicing process.
Lots of fun but it takes a ton of time and the better you understand the reasons for the FR & Z the better you are at making good choices in terms of design tradeoffs. The better you understand the underlying reasons for non-linear distortion and what is & is not audible, the better your chance at getting a good design.
post #5 of 9
^X2
Also, if you want to really get your feet wet, I recommend getting a digital crossover to mess around with, I have the DCX2496 and it is a very powerful piece of hardware.
post #6 of 9
Thanks for the replies. I will be looking into ETF 5.0. Any other solution has got to be better then SW. As for an electronic crossover, I'm sure I can dig up something from an old stash of goodies. The advice is wonderful. Thanks Kevin and cixelsid and Army.
I do agree. I probably should of given some background. As for my experience, I am a professional A/V consultant for 10 years now. Five years prior to that I programmed and monitored surface mount machines (I know my way around a electronic work bench ). My fabricating, building and finishing talents are exceptional. I have just about every tool imaginable at my fingertips. I am also a 20 year veteran R/C pilot (heli for 5 and plane for 20) and scale plane designer/builder to boot. My father was a 12v shop owner for 25 years. He was building cabinets professionally as early as the late 70s and is now a senior Linux admin and programmer of various languages. He is also a R/C enthusiast with another 15 years experience on me. So I guess you can say I have the building, finish work and PC experience down and enough knowledge to be dangerous. I am just limited to only old programs he used back in the 80s such as Trans Dimensional Research (a cabinet design program that run in DOS). I want to gather as much information and chose a good design program so he and I can hack on the new software together. I want to get a jump start on my learning curve so I can keep up with him. I know it will take a lot of time and studying on my part. He on the other hand will have a lot of brushing up to do. I hope that gives a better idea of my background.
post #7 of 9
I really like Praxis & LSPCad. Liberty Instruments is run by great guy.
post #8 of 9
Speaker Workshop is not all that hard, comparatively. Getting it all set up, gated properly, etc. is only slightly more miserable in Speaker Workshop than some other alternatives. And it doesn't have all the tools you need built in, so it's a little more round-about. Slow, but not impossible.
There are a couple Linux packages that might work (I have yet to get them to compile though I've only put marginal effort into it), and then we get into pay software. Fuzzmeasure for the Mac is great (no crossover work with it though). LSPCad, Soundeasy are probably the next steps up (though LSPCad doesn't measure, you use some other software for that - I forget which at the moment).
C
post #9 of 9
I have been using Praxis for some time to do all measurements and then use SoundEasy for all my crossover modeling. You can also do all your measurements SoundEasy though. John Kreskovsky has an excellent guide that walks you step by step through the design process using soundeasy for everything. I haven't seen another step by step guide as good for any software.
http://www.musicanddesign.com/Guide.html
john
