Usage model: MKV file with multiple audio tracks and subtitles tracks.
Right now, only solution I found to change the playing track is to go to the bottom right icon, right click on the mouse, select the track.
Is it possible to send a command to the splitter, so that it will rotate through the audio track or subtitle track. Kind of an 'audio channel +' and 'subtitle channel +'.
Ideally a simple command prompt command line, so we could tie this with Eventghost or Girder.
Any idea
Any idea
