I just put together a budget 5.1 system and I am using 4 pioneer speakers for my front and back channels. The smaller of the 2 are still pretty large, 3 way 12 inch woofer etc. I want to know if I can double up my front channels with 2 speakers per side. The speakers are 6 ohms and they handle roughly 150 watts for the bigger pair and 120 for the smaller pair. My receiver pushes 100 watts per channel. If this is possible I will be adding a much smaller set of speakers for my rear sound..
Thanks =)
Thanks =)
