Originally Posted by ITALIAN926
Boy o boy. My A20 came in , and several of the HDDVDs that did not load on the up5000, plays fine on the A20. The pixelalation that occured on 2nd half of Good Fellas is not there with the A20. A sealed Blood Diamond still wont load on the A20, and the pixelation on Polar Express is still there, in fact, like 5 chapters are unplayable, and it stops the player.
What I find strange is that I moved the UP5000 loader to another UP5000, and it was the same result. How could that type of problem (good fellas at 1:02:58 seconds) happen on two different units, same loader?. Could a bad loader be the culprit for such an exact problem?
Anyway, the UP5000 seems to be OK on most HD-DVDs. and Im still looking for my "perfect" combination. I just bought ANOTHER UP5000 that had a broken front display, but supposedly plays perfect. I'll see how THAT goes. Im also PO'd off at the TrueHD audio dropouts, so Im also considering finding a Toshiba HD-XA2.
So, I really have no answers. It seems to be a combination of a bad loader , and I have to clean the discs ?
Yes a bad loader can cause these problems. I have ran into many that have problems with certain discs. The fact the problem follows the loader gives you the answer there. In theory, if fully functional, all 5Ks with the same firmware should act the same with the same loader...but there are some folks out there with unusual problems most likely due to something funky happening with a firmware update or a slightly malfunctioning component?
If you have not already, try an alcohol based cleaner on the discs that still have problems. If that still does not work then you are a victim of laser rot or just plain defective discs.
Edited by mr.kludge - 2/28/13 at 9:05pm
![The Island [Blu-ray]](http://cdn.avsforum.com/4/48/50x50px-ZC-48c95d6b_B004V2S4WY-51KbqfL8oaL.jpeg)
