AVS › AVS Forum › Video Components › Home Theater Computers › Sony VGX-XL3 1080p Setup How To
Sony VGX-XL3 1080p Setup How To - Page 2
post #31 of 35
crevi74, for the same amount of some possibly half-cooked software you will get a Sony Blu-ray player if you know where to look (Google is your friend); http://www.swoopo.com/ended-auction....FQKJxgodVlZTmw
post #32 of 35
Need USB connector wires for your internal OCUR tuners? here is where to get it at $5.00 compared to $60 with Sony; http://www.pccables.com/cgi-bin/orde...bles.com&rcode
post #33 of 35
My Video Card Died
How do i get a replacement that will play threw the hdmi
i have tried a 8400 gs that say it is HDCP but when i try to run the cable tv it says it is not complaint
Help!!!!!!!!!!!!
post #34 of 35
Go to; http://servicesales.sel.sony.com/eco.../web/index.jsp and contact them with the part number (which should be on the video card) or just tell them the model number (VGX-XL3) and request for the HDMI video card.
Also be ready to pay good money, yes, anything Sony is expensive for some funky reason.
post #35 of 35
Just resurrecting this thread to say I used techieg's regedit trick. there was only two instances of displayhdtvres. changed value to 0. 1080p success. Took me awhile to get screen size right. Had to use a setting on the TV, Sony Bravia.
