AVS › AVS Forum › Video Components › Home Theater Computers › Cant see DVD Cover Art in Vista Media Center
post #1 of 6
I am using Vista Media center with video_ts files thanks to a poster her who showed me the Vista hack. But now I still cant get my DVD cover art to show. I have searched and tried about a hundred different things and still no go.
I have my dvds ripped into their own folders in my MyVideos folder.
For example, I have a folder called "Transformers" in the MyVideos folder. Inside the "Transformers" folder is a "video_ts" folder containing the .vob and other files. I also have an image I downloaded from google named "folder.jpg" inside the "transformers" folder.
The video plays fine, but no cover art is displayed. What can I be doing wrong?
I have:
Owner/documents/myvideos/transformers
Inside that is:
Owner/documents/myvideos/transformers/video_ts
And:
owner/documents/myvideos/transformers/folder.jpg
post #2 of 6
Nevermind, got it!!!
post #3 of 6
How did you do it?
post #4 of 6
Have you got full movie information or just coverart?
DVDID.xml is the search if not
Cheers,
Wo0zy.
post #5 of 6
http://thegreenbutton.com/forums/thread/212698.aspx
Handy little program for doing it exactly the way you want. I use this for Online titles and MyMovies for my Offline to keep it all neat and sorted. This program is nice if you read completely through the thread and follow the scattered instructions.
Good Luck
post #6 of 6
Originally Posted by Joe Hendrix View Post
How did you do it?
When I found a cover in google that I liked I would place it in the folder and rename it "folder.jpg. I didnt notice until I was about to pull my hair out that it was already being named a 'jpg' so I was actually ending up with "folder.jpg.jpg"
Once I right clicked and named it just 'folder' it showed up!
