I'm trying to connect my DVI-D video card to my Samsung HL-S5086W via a DVI-D to HDMI cable. I set my card to 1280x720@60hz. The TV can see it, but cuts off the edges. Its about a icon's width worth of an edge it's cutting off. i was wondering if this was normal, or if i should change the resolution or if the TV has a setting.
Another thing i noticed was if i change the aspect ration from 16:9 to 4:3, the signal becomes more square, and even this shows the picture is cut off.
