AVS › AVS Forum › Video Components › Home Theater Computers › Crackling sound with digital out
post #1 of 7
I just connected my ONKYO HT-SR700S to my media center via an optical out cable. I have an ASUS P5AWD-E Premium board with onboard sound. I am running MCE 2005. I have noticed that when I move through the menus on MCE, I seem to get a loud cracking/spitting noise out of the system. At the same time this occurs, I notice the digital signal thats displayed on the onkyo reciever dissapears for a second. Any ideas, why this would happen? Other than this issue the sound system works fine.
Thanks in advance for any comments
post #2 of 7
might be the sound card drivers suck
post #3 of 7
I use coaxial out of my Asus board and don't have problems like that. It could be any number of issues, I would start by using a coax cable. That should tell you if it's a cable problem or a configuration problem.
~Jay
post #4 of 7
Ive had that problem before, I cleaned the fiber optic part of the cable and all was better. Hope that helps.
post #5 of 7
Is this onboard ADI Soundmax? The Asus drivers for these are (as bulls points out) erm bull.
I originally gave up on my P5 board's onboard audio under XP although oddly enough it was always OK under Vista. However a few weeks ago I decided to have another try as I wanted to use the optical (TOSLINK) port for something.
Anyway, after some rigerous testing I discovered that it was the DTS Connect features which were causing the problems you mention as well as (for some weird reason) random lockups. I eventually found that the "SoundMAX_Audio_v6106260" drivers (available from the Asus Website) fixed the issues although they don't include the DTS components. Oh well, at least it half works.
As well as the DTS issues I also read that Asus messed up the filters creating overly high output at some frequencies. Again, I think the drivers I mentioned above should help with this. You should be able to see if this is a problem for you as I think it only effected "processed" audio not bitstream.
Hope this helps.
Wo0zy
post #6 of 7
Make sure you don't have the audio set to a resolution that it can't support. I had a Soundmax on a Asus board that I found through tons of tinkering that it only supported 44.1kHz.
post #7 of 7
This has been a nightmare! I can't seem to get digital output from the onboard optical out. It seem to only transmit sterio. I have the Cmedia 9880 sound chip with the latest drivers. I'm thinking of just purchasing a soundcard instead of using onboard audio. Any thoughts?
