Originally Posted by Hughman
The single shelf ECS-1 unit should work just fine. The shelf is 16 inches deep which will comfortably support the PJ and with the entire shelf/wall bracket unit being 22.5 inches deep this leave 6.5 inches between the rear of the PJ and the wall to accommodate cables which is more than enough room.
I see you have it or something similar installed.
How far back is it from the screen? Is brightness ok?
If it works I might considering using this idea. It looks damn good.
