I got a setup question - sorry but first projector
So I went to projector central and set my screen -- 110 inches 1.3 gain
The site tells me that 14' 6" is the optimal distance. Now that is leaving the Zoom unchaged at 1.48.
This leaves me with 2 questions.
1) Is that 14.6 from the front of the projector or the middle or the back? The thing is 1.5ft long so that makes a difference
2) Is the 1.48 zoom "optimal" ? I can move the projector further back even though it would show the cable. I can live with that, but just trying to figure out what the best distance is
I will be absolute centered with the screen and the bottom of the lens will be about the top of the screen
I've had mine up now for almost 2 years and it leaves me nothing to be desired. I suppose I would pop for an inexpensive CMS device if one should happen to come my way, but I don't ever sit there and wish I had one. I use a 10 ft wide SMX AT 2.40 screen with a pretty neutral gain, 1.16 I think, and this combo is great. BTW, I have a 9 ft wide 2.35 Firehawk that will go into the AVS classifieds if I can ever get my act together and take the time to actually post it.
hopefully not inside!!
