AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › RS2/ PRO-FPJ1 Owners: Setup Discussion Thread
RS2/ PRO-FPJ1 Owners: Setup Discussion Thread - Page 115
post #3421 of 4190
Originally Posted by curt248 View Post
What do you guys think? Has anyone compared the two projectors? Should I set my sites on a used rs2 or rs10? I'm currently leaning a bit torwards the new epson, but could be swayed if the picture quality is noticeably better than the epson on the rs1. This is really hard to do without seeing any of the projectors in person. Even then, there are so many variables that a side by side comparison would be the only way to determine which looks better in each situation.
I was in your situation and bought a second hand JVC HD100/RS2. I demoed the Epson too and it is a great PJ but too "digital" looking and artificially sharp to my tastes. JVC delivers a much more pleasant film-like picture and those blacks are unbelievable! Also the DI on the Epson was noisy and the contrast was obviously lower without it. Also the JCV is better constructed, the Epson felt plastic and flimsy... I'd say the brightness on both is about the same. I didn't like the Epson's interpolation at all! It makes everything look like a video game.
All in all the used JVC RS2 is a better choise if you want the best bicture. I love mine!
post #3422 of 4190
How much did you end up paying for the rs2?
Did you demo the epson 8500ub/9500ub or the 6500ub/7500ub?
Where shall I look for a used rs model?
post #3423 of 4190
I demoed the Epson 5000, I don't know the equivalent US model number. It was last year's model. I bought the HD100 calibrated and lamp time only 280 h for under 2.500 Euros (new about 7.000 Euros). The Epson cost about the same.
post #3424 of 4190
I have problems with color uniformity and I send my projector for repairs under warranty. I'd like to ask what kind color uniformity can you expect from this projector before it's not a feature but a fault?
In one review the color uniformity in color temperature was about 150 degrees but with my unit it was 450 degrees. There was about 15% increase in red in the bottom of the picture and upper right corner.
post #3425 of 4190
As a general rule figure RS2's in the $2000ish range. Why? We just sold (well 6 months ago) JVC's last lot of RS2 refurb's for $2399 with virtually no hours and full warranty. That sort of set the market.
post #3426 of 4190
I have a Pioneer FPJ1 that I am really enjoying, my question is why does the picture look so much more vibrant with the lamp on high power? The picture is noticable punchier and seems to be more detailed. No matter what settings I change, I can't get a similar picture using the normal lamp setting. I am throwing 15 ft. on to a 103" Carada BW Gain 1.4 (in actual use 1.2) in a light controlled room. It would seem to me (given the throw distance and my smallish scren size) that I should be able to use the normal setting and get the optimal picture. I am using the exact picture settings recommended by Alan Gouger on the first page.
Thank you in advance for the help!
post #3427 of 4190
Originally Posted by Milt99 View Post
Ian,
What's your budget?
You didn't mentioned needing an AT screen soooo.
The Carada screens are, imo and others, unbeatable for the price.
Excellent build quality, PQ and support.
SeymourAV is also a great company. I have one of their AT screens, so I can't speak directly to their non-AT but I would be pretty positive that they're in the same league as Carada.
Up the scale is the Stewart StudioTek ST130.
Probably the standard for this type of screen and priced accordingly.
Sorry for my ignorance - what's an AT screen?
I would like to stay under $1k.
It appears that the Carada screens get a lot of positive comments for quality, value and service, so I'm certainly leaning that way currently. Thanks for your comments too, Tom.
Any thoughts on which of Carada's screens would be the best match and why? 16:9 vs. 2.35:1? Gain? Model? Size?
Cheers, Ian
post #3428 of 4190
If you plan on putting your center channel speaker behind the screen, you'll need an AT screen. Acoustically Transparent.
post #3429 of 4190
Sorry - didn't recognize the abbreviation. No, I won't need an AT screen - all 3 front speakers are on stands in front of the screen.
post #3430 of 4190
Cheers, Ian
Aspect ratio is totally your call.
I'd give Carada a call and talk to them about your options.
post #3431 of 4190
Cheers, Ian
I bought a Carada Cinema White, Precision Series 100in 16:9 from them for my RS2. It was recommended by AVScience, and also Carada was more than helpful over the phone.
Few things to consider when purchasing:
- Light into the room - Mine is capable of being fully dark
- Type of projector - RS2
- Viewing distance
- Space on wall
- Type of frame - Criterion vs. Precision; I went with less-expensive Precision frames - same fabric is used on each one
- Viewing habits - We watch primarily movies, but some TV will make it's way when I buy a set-top box. We decided 16:9 (1.78) versus the 2.35 as it's most versatile.
Ideally, the Masking system gives the best of both worlds of 1.78 and 2.35, but price was bit high for me.
Give them a call, strongly recommend. Also, sending them pictures of your theater, explaining the light that comes in there, etc. will help.
Click my signature if you want to see what I did.
post #3432 of 4190
I'm in this process right now installing a Seymour.
Professional calibration on Thursday, so I'm under the gun to get it finished.
post #3433 of 4190
dave7,
As I remember, you ordered your XD screen right after I got mine set up.
Good luck with it.
BTW, just booked a date to have my RS2 calibrated.
I'm looking forward to the results.
I'm thinking Sin City & Braveheart double feature.
post #3434 of 4190
High lamp equals more light output. More light output equals more light to your eyes, which yields the appearance of a more poppy image. Drawbacks are raised black levels, shorter lamp life, louder fan, etc...
post #3435 of 4190
Be forewarned, after a steady diet of retinal burning brightness you will adapt to it and its current poppyness (is that a word?) will fade. You will constantly seek ever greater brightness until your bank account is drained, you're alienated from your family, and your life is ruined by this addiction. The first step to recovery is admitting you're a projector junkie.
post #3436 of 4190
True true.
post #3437 of 4190
dave7,
Good luck with it.
OK - I finally have the Seymour up and all my equipment placed, and yesterday morning got the FPJ1 calibrated by Gregg Loewen. Man - he did a lot of work and got the gamma spot on. He told me all kinds of things the went in one ear and right out the other. He forgets more on this stuff than I'll ever know.
I had to build my own screen frame to fit my installation and am not totally finished, but the screen itself is done and up, and the center channel properly place (OK - it might be on the high side, but I can lower it whenever I want).
So now my screen is roughly 3 feet from my back wall. I can easily walk behind it. This allows me to retain my diffusors and absorbers on the wall, and hopefully improve on my two-channel performance. It might even improve on my acoustically certified room, but I'll have to re-submit some measurements to find out.
The picture quality is stunning as expected. The weave of the screen is not perceivable, but does rob some light output. Having the center placed behind it is great for sound, and great for simplifying my equipment placement and cable runs. Gregg turned up my lamp, but since the FPJ1 is inside a hushbox (partially in view in the upper right side of the Seymour 1 photo), there is no added fan noise.
I still need to tidy things up and finish building some more pieces, but in all due time.
post #3438 of 4190
Very cool dave.
I noticed you have Legacy Speakers and what looks like Jeff Rowland amps.
Very nice.
One of Greg's cohorts, Michael Chen, is scheduled to calibrate my JVC in early March.
post #3439 of 4190
Thanks-
I'm glutton for controversy on this one - yep, Legacy speakers, but Theta amps - please no flames...I don't base my purchases on tests or numbers, just my eyes and ears. The Seymour screen was a big leap of faith since I hadn't seen one before. I figured I could always go back to the Stewart if I didn't like the Seymour.
My Theta Dreadnaught did not work well at all with my previous Focus 20/20 main speakers. The combo was great on piano and vocals, but no bottom end to speak of, and the 20/20s measured solid down to 16 HZ, so the lack of low end was very noticable. The Dreadnaught worked really well with my center and surrounds though.
Some time after switching from the Focus 20/20s to the Whispers, on a whim, I tried the Dreadnaught on the Whispers just to re-verify what I heard with the Focus. To my amazement they sounded as good, if not better than my monster Krell, with good, solid bottom end and still excellent vocals and such. This was vastly different from the Focus experiment. Once I realized this, I got some Enterprises to try next to my Krell and I chose the Enterprises, which was a nice overall improvement, but mostly with SACD and DVD-A formats which suddenly became noticeably superior.
Before the Krell I had Mac, Bryston and others, but I digress...and this is a video forum.
So my conclusion is that it really is all about synergy. I don't feel the Theta's are amps that will "drive anything" like a Krell or Mac, or even maybe Rowland would, but they are wonderful with my speakers in my set-up, and I've demo'd some nice stuff to compare.
post #3440 of 4190
Congrats! Greg certainly knows how to make a display shine!
post #3441 of 4190
Thanks Jason - I booked him back in November based upon some recommendations from somewhere...I don't even remember now. We both had delays until now. Nevertheless, I don't recall knowing you guys also do this work...sorry. I usually support AVS whenever possible in appreciation for having this forum.
post #3442 of 4190
Has anyone who owns the Pioneer PRO-FPJ1 been able to use the discreet V-Stretch On and V-Stretch Off via RS-232?
post #3443 of 4190
Sorry to throw out this question ... but does anyone use the RS2/FPJ1 with a PS3? I use my PS3 as my primary Blu-ray & DVD player with this projector. Could you please share your settings for certain options?
Like ...
VIDEO SETTINGS
BD / DVD Cinema Conversion - Automatic / Video
* Apparently people were saying on the RS20 thread that setting this to Video would fix the motion blur issue?
BD / DVD Upscaler - Off / Double Scale / Normal / Full Screen
* I have this set to Off since I read the Upconverter on this projector is better than the PS3 one
BD / DVD Video Output Format (HDMI) - Automatic / RGB / (Y Pb / Cb Pr / Cr)
* I have this set to Y Pb / Cb Pr / Cr
BD 1080p 24 Hz Output (HDMI) - Automatic / Off / On
* I have this set to On
DISPLAY SETTINGS
Video Output Settings - HDMI (1080p / 1080i / 720p / 480p)
* All selected
Cross Color Reduction Filter - Off / On
RGB Full Range (HDMI) - Limited / Full
* I have this set to Full
Y Pb / Cb Pr / Cr Super-White (HDMI) - Off / On
Thanks for your help, just look to setup my PS3 with my FPJ1 at the optimum settings. Thanks.
* Please also feel free to share any other optimizations you might have made to get better PQ.
post #3444 of 4190
Like ...
VIDEO SETTINGS
DISPLAY SETTINGS
* All selected
I use a PS3 for movies and gaming. All my settings are pretty much in default with no issues. I keep hearing of motion blur on this thread but either I am not as sensitive to it or I conclude that it is in the source. I plan on doing some Dirt2 tonight. If you like I can jot down my specific settings.
Chris
post #3445 of 4190
* I have this set to Full...
If you set RGB Full Range to full it will crush low level detail. I would set this to limited. Colors may look deeper but this would be similar to turning a black level enhancer to high on a TV.
post #3446 of 4190
I see motion blur will switch to that setting this weekend. Movie will be gamer so lots of motion. Will report back - great question
post #3447 of 4190
Really? I sort of know what your saying, but I always thought that Full would give more detail, not crush detail for blacks. Doesn't Full actually give more detail for black? So confused.
post #3448 of 4190
Chris
Please do jot them down. Would be interested to see what you got and are happy with.
post #3449 of 4190
I have noticed it alot too and just read about the Video setting. I am going to try it out tonight as well and report back if I see an improvement.
Also was curious if most of you forced the 24Hz(p) setting ON or left it to Auto. I am assuming NO one has set it OFF. Right? As most blu-ray's if not all are encoded at 24p ... right?
post #3450 of 4190
That was my understanding as well be try it out. and it will be immediately obvious to you. Loss of detail on my FPJ1, the Pioneer 6010 & 6020 plasmas I had and the Samsung B650 LCD that I have now. I lose quite a bit of detail with RGB set to full.
