Originally Posted by DaViD Boulet
No it won't. It won't work for any standard 2D projector, 720p or otherwise.
What that write-up failed to make clear is that this device is intended for owners of *** 3D *** projectors that are 720p, or (a bit rare) 2D projectors that can accept direct-in 120Hz for use with an outboard transmitter.
To my knowledge the RS2 doesn't accept 120Hz input of 720p signals. Plus, lag-time on the panels would make ghosting absolutely horrible even if it could work.
DLP is a different story since each frame can be literally on or off, eliminating ghosting entirely except for what may derive from sluggish LCD shutter eyewear.
Actually I thought it was pretty clear "You'll still need a projector that does 120Hz of course"...............
2 devices - 2 projectors and you can use it for 3D
