Is there a significant downside of a sub in the attic?
I was thinking about an NHT1259 (well, now MAD1259) project and then got to thinking about how car guys always put subs in the trunk and such. So... that put the possibility of attic mounting subs with no cutout in my head.
So really I have 2 options for how to build the sub:
a) build to be placed in the attic with no cutout and have freedom to place it almost anywhere on the x/y plane but 8 feet above the floor in the z plane and with a sheet of whatever "typical ceiling material" is between the sub and the listener.
b) put sub under one of the mains and have no issue with filtering through the ceiling, but have very little placement flexibility.
My guess is that the placement options available through ceiling mounting are going to potentially offer better sound than putting it in the room but be chained to one of 2 very specific locations.
While I can build and test both ways, I kinda would prefer to avoid that... the cabinet designs are going to be quite different for the different applications considering the aesthetic concerns if it's inside the room vs. attic placement where the only real design constraint is going to be fitting it through the access hole into the attic (and figuring out how to lift such a behemoth up there and how best to move it around while walking on rafters since the living room is a good 20 feet from the attic access location.)
