Here is my story. TV went out, a bunch of power button flashes then the lamp led flashed once every 5 seconds. BUT, when I tried to turn the TV back on it WILL light up for about 10 to 20 seconds, show content and then cut off again with the lamp led flashing. looked at the ballast and lamp from behind and the lamp fires off and the very first try every time, runs for 10-20 seconds and same thing.
Bought the repair kit mentioned here and replaced everything from the kit. Also bought a new bulb at the same time for good measure, didn't want a damaged bulb to potentially damage something else.
Now with the new bulb, I get absolutely nothing. The ballast tries to fire the bulb, as before, cycles about 6 times and then you get the flashing power light, followed by the lamp led.
I put the old bulb back in to try it out and it fires the bulb the very first time, with exactly the same original problem, 10 to 20 seconds then lights out.
With the new bulb, when the ballast fires you can see the sparks in the bulb every time it tries to fire but the bulb will not light.
I don't think I had a ballast issue in the first place but I don't mind that I replaced the ballast parts. I think I may have gotten a bad replacement bulb and just both bulbs are bad.
Anyone else have any thoughts before I buy another bulb?
