Jerry -
I also am confused about the bulb situation. There appears to be three manufacturers of the bulb: Phillips, OSRAM, and LTI. Which one is the actual OEM replacement for Panasonic is anyone's guess.
Here are a few statements pulled from the internet:
Very confusing, to say the least.
The bulb I got says "Phillips" and "Made in China". I am now assuming it is a LTI product. Although it seems to be working now with the ballast repair kit, it may quit at any time.
But, I don't think I am willing to buy directly from Panasonic at $300.
In short, it could be the bulb, or the ballast/power supply that is killing the bulb. I didn't replace the transistors in my ballast also; I wonder if that could be the problem?
Please let us know what your solution is. Thanks!
From some time ago we notice that some lamp distributors started selling generic projector lamps for some of the most reputable brands of TV and projectors of the market, we conducted a testing to know how good these aftermarket lamps were. Our results were a total disappointment. Most generic lamps failed after a few hundred hours in the best case. In others cases the color quality is not like the original, but in almost all cases the life of those lamps is significantly less than the original.
Our testing confirmed what we hear from customer who bought generic lamps. ALL generic lamps failed before 800 hours of use.
Another problem of generic lamps is the risk of damage to your unit. Although, we didn't experience damage units, these generic lamps have the potential to damage a projector beyond OEMs warranty and there is a risk of explosion or fire.
How do you know if your lamp is generic or OEM (Original Equipment Manufacturer) ?
This is one of the most difficult task because generic brand are almost physically identical to OEM lamps but most OEM factories use a specific barcode and bulb from the top lamp manufactures like Philips, Osram or Ushio, Buy your lamp from a reputable source and ask for OEM before buy it. If the price if significantly less than OEM, then probably it will be a counterfeit or generic lamp.
Our recommendation is always to use OEM. Take special care with Ebay sellers and online discount stores because a high number of them are selling generic replacement lamps, without telling it to you, to raise the profit.
This is a brand new in the box lamp Manufactured by Osram. The same lamp that is in your PANASONIC right now.
# Brand New Original LTI Part
# Lighting Technologies International (LTI) is the industry leader in the design, development, and manufacturing of projection lamps. LTI's lamps are specifically designed for optimal effectiveness bringing longer life and enhanced stability. Enjoying unparalleled performance at markdown is the LTI way. LTI, leading the way in lighting technologies for projectors and projection TVs. LTI is proud to be a part of Philips!
# This is the equivalent alternative for Panasonic part number TYLA1000
As of March 2008, Phillips has acquired LTI (Lighting Technologies International) and many sellers have begun selling LTI lamps but actually telling customers that the lamp is made by Phillips when in fact the lamp is not. LTI is an after-market maker and not the original maker for the following manufacturers of TV’s (See Below).
OSRAM/SYLVANIA is the OEM manufacturer for all RPTV/DLP lamps. Phillips is the inventor of the UHP lamp but PHILLIPS DOES NOT SELL TO END USERS, NOR DOES PHILLIPS ALLOW RESELLERS TO SELL BARE LAMPS TO END USERS. So please beware of this scam, someone will sell you a Phillips lamp but Phillips will not warranty it. OSRAM is the only OEM maker that allows CERTIFIED resellers to sell bare lamps to end users, OSRAM is required by the Federal Government to sell all lamps through Sylvania in the US.
If you have an OSRAM lamp in your TV we highly recommend replacing that lamp with a Philips. It’s no secret Philips is the innovator of Ultra High Pressure (UHP) Mercury Lamps (created in 1995). The quality and dependability of Philips lamps are much greater than OSRAM, or any of the generic brands out there (LTI, APO, etc.. The combination of better “burners” and more advanced drivers (the ballasts) are a few reasons why Philips lamps outlast the competition.
and I measure the transistor all of them have same measurement.
