Originally Posted by
hiind
Sadly can't use the CAST TECHNOLOGY as my amp is the Krell 400xi which doesnt do cast.Does the Esoteric do SACD's?
Thanks for the input.
Have you tried the Krell SACD Standard? Its more in line with the KAV-400xi, and nicer for your wallet at 4000$. The Esoteric plays SACD, but both it and the Krell EVO are a full step higher than the Krell Integrated.
What are your goals? Just scoping out the joint? There are many nicely built units from 800-10k$, depending on features, build quality, and support, that will land you at a price range that you can justify. You should listen to as many as possible and determine which player(s) satisfy your needs and wants.
What is your current source?
