I own the hk avr 247 (7.1 channel reciever) and the hkts 15 (5.1 channel speaker system). I was considering adding two more surround speakers to take advantage of the 7.1 on my reciever. It says in the manual that dolby digital and dts digital only offer 5 discrete channels. Does this mean that if I add two more surround speakers that I will have to use logic 7 surround mode to take advantage of the 7 seperate channels and dolby and dts digital will not be used at all. It doesnt sound so appealing if I cant use those surround modes.
Question about harman kardon avr 247
AVS Top Picks
post #2 of 13
12/23/07 at 12:17am
post #3 of 13
12/23/07 at 3:52am
post #5 of 13
12/24/07 at 8:59pm
post #6 of 13
12/24/07 at 9:40pm
post #7 of 13
12/24/07 at 9:42pm
post #8 of 13
12/24/07 at 11:18pm
post #9 of 13
12/25/07 at 10:55am
post #10 of 13
12/25/07 at 11:44am
post #11 of 13
12/25/07 at 1:12pm
post #12 of 13
12/25/07 at 2:34pm
post #13 of 13
1/15/08 at 11:40pm
However, in this case you are not completely correct. 247/347 supports 2.0 PCM through optical/coax/analog and HDMI and Logic7 can be applied to these. Logic7 can be applied to DD/DTS through coax/optical/HDMI also. However, these receivers also support 5.1 PCM through HDMI. I had a 247 and can confirm that. However, it cannot expand the sound field to 7.1 using Logic7 or Dolby PL IIx for PCM 5.1 content.
