seems like this thread has been dead for about a month and i'd hate to revive anyone's obsessions (blue),
Oh come on...that's not really fair...you're admitting below here that you don't think this to be an "abnormal anamoly" and then you call the thread an "obssession"? Come on...
but i am experiencing the same exact phenomenon as blue.
...was a matter of time because I KNOW I was not imagining this volume drop...
my set up is as follows: ps3 (40gb version) through HDMI to Onkyo 705 through HDMI to sony Bravia XBR LCD.
Just like my setup from my Panny 10A to my Onkyo 605 to my Sony SXRD...
i just got the ps3 last night and hooked up it, went through the firmware update through my wireless lan and looked to play the BD version of spiderman 3 which came with the ps3. when dynamically changing the audio output stream from bitstream to LPCM, the loudness dropped significantly. in fact, i usually listen to sources at around -30db and when i switched to LPCM, i had to crank up the volume to around -17b to get to equivalent levels and quite frankly it didn't sound significantly better. the DD 5.1 that comes with the BD disc jst adds more color and 'oomph' (no other way to put it). after reading this entire thread to no apparent definitive conclusion, i have to acknowledge that this may be an onkyo issue since i don't have the panny HW that blue has. i recall someone with an 805 indicating that he experiences sound loss using LPCM only 4db lower than corresponding DD 5.1 or DTS. I would be curious to know if other onkyo owners could respond with their experiences and workarounds. i also need to try out other BD discs to make sure Spidey 3 isn't a fluke. thanks,
I dont think Spidey 3 is a fluke disc, its just that somethings wrong with the way these Onkyos process the LPCM tracks with missing LFE and other abnormalities; it was explained to me -- because I am getting the EXACT same phenomenon as you whereby when I play BITSTREAMED material they sound MUCH MUCH better than PCM'ed tracks -- that when a DOLBY TRUEHD track is on a disc, there is also a "running parallel" Dolby Digital mix alongside it...so, if you select the TrueHD track from Spidey's menu, and you have your player set to output TrueHD in BITSTREAM, and your player doesn't output TrueHD in BITSTREAM, then the secondary Dolby Digital track is called upon to play instead...this is what happens on my Panny 10A, and no matter what, EVERY TIME I PLAY A DOLBY DIGITAL TRACK instead of an UNCOMPRESSED or PCM VERSION OF A TRUEHD TRACK, the volume output goes up tremendously with more "punch" as compared to the PCM/uncompressed mix...I'm experiencing the EXACT same thing as you.
