AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › OFFICIAL "HELP ME CHOOSE A PLAYER" THREAD: Can't decide? Start HERE.
OFFICIAL "HELP ME CHOOSE A PLAYER" THREAD: Can't decide? Start HERE. - Page 443
post #13261 of 15216
OK, I've had it with my Samsung BD-P3600... no MKV support, or it's so bad as to not matter.
I don't expect much from a player. Besides playing Blu-Ray discs, I want to be able to connect to my PC and play as wide a variety of video files as possible. And I'd like to be able to pause those videos, walk away, come back, unpause, and resume viewing... something which the Samsung could never do (after a couple of minutes paused it'd stop the video). I don't need WiFi as this player is right by an Ethernet connection. It connects to the TV with HDMI, no receiver, so I really don't care about an array of audio outputs. I'm looking at sub-$100 players. If there's anything to specifically avoid or go for, great... otherwise I'll probably just get another LG as I'm really happy with the BD670 I have downstairs.
ETA: is there any player with particularly good WiFi performance? I had no issue with my LG when it was attached to a WAP, but I moved the WAP and set up wireless, and now it doesn't play well :-( I may bring the LG upstairs and connect it to Ethernet and get a different player with better wireless rather than buy a new WAP.
post #13262 of 15216
Just looking for the best HD picture..i will not use internet features at all and i will NEVER do firmware upgrades...so out of the box which model gives you the best picture quality? Price under $200 Thanks!
post #13263 of 15216
There's been a lot of discussion on this in the Help me Choose a Player thread:
http://www.avsforum.com/avs-vb/showthread.php?t=959985
There's also a dedicated thread called not all are created equal, or something like that.
In short: Panasonic or Sony will best meet your requirements.
S~
post #13264 of 15216
I have a Sammy & Sony
The Sony has the best PQ
both update firmware very easy ... I don't understand why you don't want to do a firmware update ?
post #13265 of 15216
Which Models do you have? Thanks!
post #13266 of 15216
Samsung BD D6500 has the best BD picture. I compared it to Sony S580, S780, Panasonic BDT210, BDT220 and LG 670. For the Samsung I use USER settings with +2 for sharpness and +1 for noise reduction. The Panasonic BDT220 has the best DVD upconversion and sound.
post #13267 of 15216
Unfortunately, Samsung also has the worst reliability. And most people agree that for BluRay PQ, all players are pretty much the same. The biggest difference is for SD DVD upconversion and audio (if you use analog outs).
post #13268 of 15216
Then you are going to run into problems. Most firmware upgrades are to allow new releases to play, so good luck. Firmware upgrades are very easy if you have internet access.
post #13269 of 15216
+1.
Jacob
post #13270 of 15216
Based on the dedicated threads (check them out), they seem to be pretty close in PQ (although the 500 is not available yet), with Panny being faster to load and the Sony having SACD. Don't assume you won't need the duplicate streaming; my 2011 Panny BluRay player (110) had much better streaming PQ than my 2011 Panny plasma (VT30), so I'm glad not to have to rely on my display for streaming.
The 790 is also not available yet.
post #13271 of 15216
I'm considering a new BDP. My current Sony S57 has been having locking issues. It stays on a screen with a spinning disc and does not leave that screen. Usually if I unplug the machine it will "sometimes" fix the screen and will play with no issues. Since my kids now no how to use the player and watch movies on their own I really can't explain to them how to reset it.
Here are some of the things I am looking for.
-Netflix Streaming
-Internet radio, Pandora etc
-Does not have to be WiFi, I have Ethernet at the machine
-3D is not a big deal, if the machine has it, thats fine, but it really doesn't matter
-Awesome picture is a given
-I'm still playing DVD's so upconverting is necessary also
It will be used with an older Hitachi 55" VF820 TV and Pioneer 1020 receiver.
post #13272 of 15216
My system is a mid-high end dedicated theater using an Integra pre-amp processor for HDMI audio/video processing. I currently use a Samsung 1500 blu-ray player that is getting slower and clunky and not longer acceptable.
I need a new player that will integrate into the system properly (including IR distribution system) and be fast with good video - no 3D, no audio decoding in-player needed.
I was looking at the Pana BDT-220 or Oppo 93. It seems the 220 may be a more modern video design (newer than the Oppo), but the Oppo seems more bulletproof and might be a better integrating unit for my system (the dedicated IR input is worth alot to me for reliability).
Can anyone comment on (1) speed and video only quality between the two players; (2) content compatibility; and (3) any experience of reliability with IR flashers glued to the panasonic 220 or negative experience with IR input of Oppo.
Any other players I should consider (I am not adverse to spending 4x on the Oppo, but just want to make sure I am not spending the extra $$ for naught in my system).
db
post #13273 of 15216
I've searched this thread and expected to find something on the Panny BD77 or 87 players. Internet searches also don't seem to yield much information nor reviews.
Does anyone have one of these yet, or am I just stupidly assuming that they are already shipping when they aren't? They seem to be orderable at amazon and are listed as "in stock".
How fast is this "ultra fast booting"?
post #13274 of 15216
You should start a thread. Personally I don't have much interest in those models when you can get full featured ones for just a few more bucks.
Ultra-fast is quite fast because the player essentially never turns completely off when it's enabled. Waste of energy IMO.
post #13275 of 15216
I have the Panny BDT220 and Love the Picture quality/sound.
I am using the optical out to feed my high-end 5.1 HTS and it rocks. Can't really beat the price as well.
Have yet to stream Netflix on it though..
post #13276 of 15216
These days, many people would like to argue that since the optical out cannot carry full HD audio, then your system is not really high-end. But that's a quibble, since most people really can't hear the difference, and room acoustics and speakers will have a much greater effect on what you hear.
post #13277 of 15216
Truly depends on the soundtrack. On the pow boom soundtrack, it's difficult to hear the difference. For orchestral soundtrack, sound with crowds, water splashes, the difference is truly easy to hear.
post #13278 of 15216
Just purchased a Panasonic Ae7000u and would like to setup a player that can read all my iso's from a hard drive. I was using ps3 media server to stream for a few years but my current house I can only use wireless in the theater room and it stutters so bad it's not worth my time. I'm looking for a player/htpc that will give true 1080P 3D and 2D and that I can read from a hard drive and pass through full DTS-HD and Dolby TrueHD. Anyone have a suggestion? Wish the oppo 93 still played iso from a hard drive.
post #13279 of 15216
I currently use my bdp-s570 as follows:
BD video and video files from USB hard drive via HDMI to Pioneer VSX-1121 receiver.
SACD via HDMI, same routing
CD and audio files via LAN (MP3, FLAC, ALAC): S/PDIF coax output to Cambridge Audio Dacmagic Plus, then analog to DVD input on Pioneer. The video component of this output (menu browsing on screen) is handled by component video cable to DVD input.
I am ready to upgrade to 780 or 790 because they support NTFS USB drives (full-res BD files over 4 GB).
The question is: should I go to 780 or 790?
I know 790 does not have component video output, but I can use composite video if needed.
Any input / insight / feedback is welcome.
post #13280 of 15216
Understood. My comment regarding "high-end" was referencing that fact that I have high-power dedicated audio amplifiers for 2 channel stereo and 5 channel discrete 5.1 Dolby Digital and DTS (aragon 8008 power - 400 watts/channel into 4 ohm PSB Stratus Golds, Acurus dedicated digital surround processor). I refer to my setup as "high end" based on electronics, not the latest 7+ channel encoding referred to as "lossless." Are the newer surround formats better, I'd asume Yes. But my electronics and speaker setup deliver a "rock solid" performance in 2 channel stereo (critical listening) and 5.1 DVD/Blu-Ray playback.
post #13281 of 15216
Try the media server forum: http://www.avsforum.com/avs-vb/forum...aysprune=&f=39
-Bill
post #13282 of 15216
After a few years away, am coming back to the scene and looking for a recommendation. Details of set up and what I want/don't need are below (thanks in advance, btw)
- Blu-Ray player is currently DMP-BD30 and looking to update since buying a
- Panny TC-P55VT30 TV to replace TH-50PZ80U.
- Sound setup isn't anything fancy...Denon AVR-1909 to drive Paradigm Trios (in front).
I *think* the must-have features (pretty basic, actually).
1) 3D support (will only be used from time to time, but probably wouldn't upgrade otherwise).
2) load times (having to wait to even eject the tray is unacceptable...fortunately, it seems anything beats it out these days
3) Decent DVD upscalling (not a priority, though)
Special considerations given to:
4) DLNA support. Looking to get away from managing a separate Plex installation. The Panny TV has it and it's working ok, but it seems rather crude/buggy/limited in file formats. If having it on the BD would suit me better, a few bonus points here
5) Online streaming support that is worthwhile for a Canadia viewer (otherwise, will continue to use homegrown solutions).
are actually usable from Canada and can provide content otherwise (either native, or via other methods).
6) Nice if the CEC works with the Panny Viera Link (i.e. if BD isn't Panny)
What I don't need:
- wifi
- extravagant hookups (just enough to get the 3d Content to the TV and audio to the Denon AVR).
Hoping to keep this under $150 CAD but will spend more if the gain is significant. If I'm missing something, would appreciate being put on the correct path.
post #13283 of 15216
Hello,
After reading through the last 30 pages, it's seems it's going to be best for me to post and ask for a recommendation. I currently have a Samsung BD-D5300 which when it's working is quite good but there are many times when I have to unplug it to reset it due to non-responsiveness, loss of audio or video from startup, or some other irritating thing.
I need:
-ability to play from USB (not NAS), DVD-R, and BD-R with .avi, .mkv, .mp4 files
-hard network connection (mostly for firmware, possibly for Netflix or streaming in the future)
-using a single HDMI to a Pioneer receiver
-less than $150
I do not need 3D or wi-fi. Due to my location, it would be best if the player were available from Future Shop or Best Buy Canada.
They have Panasonic DMPBD75, Sony BDPS185, BDPS185, BDPS590, and a bunch of LG players. (although, if this aren't any good, I may wait until I go down to the States in the summer to pick something up)
Thank you!!
post #13284 of 15216
Ok I see couple models out but dont know what to get looking for fast and best pic have also a samsung led 47 inch
post #13285 of 15216
Originally Posted by tjkren View Post
ok i see couple models out but dont know what to get looking for fast and best pic have also a samsung led 47 inch
thanks
bd-e6500
post #13286 of 15216
Originally Posted by pinball_freak View Post
Hello,
I need:
-less than $150
Thank you!!
Bdp-s590.
post #13287 of 15216
What I don't need:
- wifi
Sony bdp-s590 or Panasonic bdt-220. See dedicated threads on both
post #13288 of 15216
Hi all,
I would greatly, greatly appreciate any advice on a Blu-ray player based on these priorities:
Non-negotiables
  • Profile 5.0
  • Full support for 24fps Blu-ray
  • Can decode all flavors of DTS or Dolby Digital to LPCM (up to 7.1) and send over HDMI to receiver (and is not limited in this respect when playing 3D content and/or when mixing primary/secondary audio)
  • Capable of sending DVD content at 480i and Blu-ray content as "source direct" over HDMI (I will be using an external video processor)
  • Manufacturer has good track record of timely firmware updates to ensure compatibility
Things that would be nice (in order of importance)
  1. Fast loading
  2. Lower price
  3. SACD support
  4. Ability to update firmware direct from machine w/o needing to use thumb drive
Things that I won't use/couldn't care less about
  • Apps/Internet browsing
  • 2D to 3D conversion
  • Wi-Fi
  • Video processing (including 24fps DVD or anything involving frame interpolation)
  • Analog output
I know the Oppo BDP-93 hits all of my "non-negotiables" and most of my "would be nice" list (except that it's kind of expensive and I'm not sure how fast it is), but I'm wondering if I can find anything cheaper and/or faster, especially since I don't need the Qdeo video processing. Thanks very much!!
post #13289 of 15216
Sony 590 meets all those criteria except source direct deinterlaces to 480p first, and it has no 7.1 analog out.
post #13290 of 15216
There are now enough region-locked Blu-Ray's out there that aren't available in the US to make me want an all-region player.
I would like the standard array of features (lossless audio, 3D support, etc). I'd also like it to perform rapidly (I hate the slow loading speeds on early-gen Blu-Ray players).
I'd also like it to be quiet (so, no cooling fan or anything like that).
I'm not really concerned about DVD playback because I have an all-region Oppo for that.
So, what would you folks recommend?
