AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Hot Link Pro Users
Hot Link Pro Users
post #1 of 5
I just ordered this system and I think I'm going to need to extend the length of the receiving eye cable. Does anyone know what kind of cable I need to do this? Thanks!
post #2 of 5
Use a standard RG6 or RG59 coax cable. To make a custom cable, use RG6, or RG59 with F connectors and then add one Male RCA to female F and one female RCA to female F adapter, one at each end.
post #3 of 5
Thanks for the reply, Mike.
The extender cable that Microsmith sells looks like it just just a RCA extension cable, which I can buy at Radioshack for a lot cheaper. Would this work?
post #4 of 5
It has RCA connectors, but it's a coax cable. I believe you need to use the shielded coax for it to work properly.
post #5 of 5
Thanks, Mike.
  Back to Forum: Remote Control Area
