AVS › AVS Forum › Audio › Soundbars › Soundbar Mounting Height?
post #1 of 3
Hi all - I might have to mount my soundbar (Yamaha YSP-1100) above my plasma, which is over the fireplace - so about 8 ft high!
Is that too high? I guess if I need to I can move the plasma higher but I like the tv lower if possible...
Thoughts?
post #2 of 3
Seems to me there are about a dozen or so YSP owners who post from time to time, but it seemed to me that no one has really done much comparative testing at various heights and different room conditions. All I can say is that most people think it adapts pretty well to a lot of different situations. Try it...
post #3 of 3
By all means... try it before any permanent wiring is done. But IMO, unless you can angle the "firing" angle down or if your seating position isn't 6'+ high, you may want to reconsider other speaker/mounting options for best aural results. Otherwise... the "spatial effects" and sound will be shooting over your head(s).
  Back to Forum: Soundbars
