It is the blue tube fluid. not hard to change, but messy and takes about an hour. Don't do all 3.
Turn the set off.
disconnect the deflection and convergence yokes for the blue tube. (the wires going from the boards to the tube)
watch out for the grounding cord for the CRT/PRT, they are a pain to remove, use needle nose, they are a spade type plug that grounds the tubes chassis.
remove the 4 screws holding the tube to the "optical box".
now the whole tube, wires and all should pull straight out of the unit.
remove the plug from the tube, it is a hex shape.
insert tube to suck out the majority of the fluid.
remove the 4 BOLTS holding the lens on the frame of the tube. they are the thingies with the springs.
suck out remaining fluid, clean thouroughly, CLEAN WELL!! CLEAN WELL!!! sorry.... had to make sure that gets through. you have to remove all algae.
reassemble after cleaning the seals.
tighten the BOLTS down fully.
fill will fluid, don't worry the bubbles will dissipate.
fill until nearly all the way to the top.
some say to empty the overflow as well, i have never bothered.
reinsert into the TV and screw into place, attach yoke wires to main board.
perform minor touchup convergence if needed through USER MENU.
don't touch service menu unless you are sure you can do it.
cross your fingers and hope you dont have a super-slow drip that will trash your TV.
Or simply lay down some plastic/paper towels for a week or two to monitor.
VIOLA!!
Mike
p.s. or pay ~ 450 bucks to have it done by a pro
Turn the set off.
VIOLA!!
Mike
