Sorry if this isn't the right forum to ask this in, but this is the closest one I could find. Anyway, I want to convert ~30 VHS-C(the small tapes, but I have an adapter for VHS) camcorder tapes into DVD format. I have an ATI All-In-Wonder capture card in my computer already(from a Radeon 9700). The camera no longer works, and my VHS player is broken. My goal is to get these 10-15 year old tapes archived before they are destroyed through aging. My questions are as follows:
- What VHS player should I buy? Does it matter if I get the el-cheapo $57 VHS player from Target, or need I get a much better one(keep in mind that these tapes were recorded on a mid-range(probably erring on the side of low-end) JVC camcorder. Any specific recommendations on VHS players(I'd like to keep the price down if possible)?
- Does S-Video vs. Composite make a difference on VHS tapes? If so, should I get a player with S-video output? The Radeon has an S-Video input, but I'm not sure that the resolution of the VHS tapes is high enough to justify using S-video.
- What resolution/bitrate should I capture at(i.e. what is justifiable for a mid-range consumer camcorder using VHS-C tapes before using space becomes wasteful)?
- Is it worth cleaning up the video digitally? If so, what filters/programs would you recommend? I don't want to spend hours cleaning it up(with 30 VHS-C tapes, that'd be a nightmare!), but if there's a quick way to make the video look better with a single click, I'd like to know. This isn't my prime concern(my main concern is archiving the analog content as well as I can), but I'd still like to know.
Thanks for your help,
Mike
Mike
