AVS › AVS Forum › Video Components › Home Theater Computers › Stutter when playing video over the LAN
post #1 of 15
I have been playing HDDVD rips, Bluray rips, and reencodes(mkv) over the network. One computer has more space and I use it to rip and reencode the movies and that is not attached to the TV. So I play the files with my HTPC which gets the files from the hard drive on my other computer. Note that both computer are using windows vista(HTPC is using Ultimate, other PC is using Home Premium). When I play the files every once in a while the film slightly stutters for a few seconds, most notably during panning shots. This happens in every film. What gives? Can this be fixed?
post #2 of 15
Your network is having bandwidth problems transferring data intensive encoded video. Lots of motion or panning is very data intensive since the amount and size of change frames is large.
post #3 of 15
This shouldn't be a problem with a 100mbit network or greater. Have you tried playing the files from the hard drive? Problems during panning shots sound more like CPU-related issues.
post #4 of 15
The problem is Vista.
Read here
And here
post #5 of 15
I have gigabit ethernet. it looks like it is a Vista problem. Hope SP1 fixes it.
post #6 of 15
Is any part of your network wireless or is it all wired?
post #7 of 15
I have a combo wireless/wired router, but it does have gigabit ports on it. Everything I am using now is wired.
post #8 of 15
Is the souce system Idle except for the support of sending the encoded files to the destination machine?
What size are the riped files in GB per hour of recording?
Is there any other device connected to the router running with any network activity when you have the stuttering?
post #9 of 15
Generally I will have torrents uploading while I am streaming but rarely go over 20KB/s which should not affect a gigabit ethernet connection. The Planet Earth episodes I ripped are about 4.3gigabytes for an hour. The other connected device is an HDHomeRun which is generally idle.
post #10 of 15
There was an update that SP1 will have a dialog that will allow you to increase the priority of the network process. This will hopefully fix the problem.
post #11 of 15
What's your CPU usage while playing the file? It seems like those files are around 13 mbit/sec, which even Vista with poor performance can sustain easily.
post #12 of 15
Your router can only receive or send content from one connection at a time so home networks can easily conjested regardless of how fast any one port transfer at when nothing else is happening.
post #13 of 15
What are you talking about?
There is no routing involved when transferring files on a home LAN. The router might have a built-in switch. Gigabit ethernet is full-duplex.
post #14 of 15
I was not talking about routing I was stating that a home router (or switch) can not perform two operations at the same time. This is because they do not have multiple send/receive buffers or multiple I/O processors.
Yes. Using a switch is much better then a hub since the signal only has to be sent to the destination device.
post #15 of 15
It's going to be fine.
