AVS › AVS Forum › HDTV › HDTV Programming › Official WWE in HD topic!
Official WWE in HD topic! - Page 8
post #211 of 572
Originally Posted by DavidML3 View Post
Im getting tons o' screen flicker and pixelation during the "in ring" events. Is anyone else experiencing this?
I am. The backstage interviews were fine looking. So far the tag match has gone on smoothly, not MUCH pixelization.
post #212 of 572
Looks like they or my cable system is having TX/ RX issues. The SD is OK so I would assume the raw feed from the MU is OK. Every now and then it just goes to garbage and starts freezing. When it's on it does look good.
I too assume the ring cams are softened just a bit. And the pyro smoke didn't help the first match.
post #213 of 572
I am getting tons of blocking especially in the dark areas of the screen. Any time there is movement I can see blocking in the dark areas. I assume this is what others are seeing too. It also doesn't help that I am watching on The Score HD in Canada on Bell Expressvu. It is a majorly compressed signal getting sent around 9mbps, and probably not even near 720p quality that I should be getting (HD Lite). The graphics look great, but I would like to see what a less compressed actual 720p/1080i signal looks like.
By the way, Raw does look great in HD, but I still can't watch it. Still not very exciting, and the score ticker on the Score is just annoying. I'll wait for Friday night.
post #214 of 572
Originally Posted by Berk32
Cable providers need to get off their asses... drop their analog services... and add all the available HD channels (including USAHD and SciFiHD)
There are many of us that have been HD 'customers' for a number of years that don't have the option of switching to any other provider....
Originally Posted by kizzo View Post
I know.. I was only joking around.
I agree! You all are complaining about the HD macrkblocking and I'm stuck watching crappy SD analog.
It's about damn time they drop the analog garbage and get more HD. @$##@^&@#%%@
post #215 of 572
Originally Posted by Droford View Post
noticed that the 16:9 framing of the ring from the main camera allows the same amount of ring viewable that used to be viewable from the 4:3 camera which means 4:3 people are seeing less of the ring than they used to now. they should probably feed it letterboxed in SD if they're going to do that.
Good. Maybe if they p!$$ off enough viewers with the SD feed, people will complain to the cable company and ask for the HD feed. But then again cable listening to the customers, that's a farce!
post #216 of 572
Anyone able to grab some HD stills?
post #217 of 572
Lilian in HD!
post #218 of 572
theres a my maria in HD
post #219 of 572
I could have done without the piercings in Ashley's lip though!
post #220 of 572
LOL Santino Marella is brilliant.
post #221 of 572
Same anyone get some images of the HD feed?
post #222 of 572
Or even a clip of the HD feed for that matter? I wish I could see it in 16:9
post #223 of 572
I do wish WWE would do a 3D week though...
post #224 of 572
Looks nice but damn I hate all the bugs: WWE, USA, and WWEHD???? Come on. It's very distracting.
post #225 of 572
WWE really needs to either have USA insert their bug for them so that it can be inside the HD cut on the full feed or send two separate feeds (which would probably not be anywhere close to cost effective just for a bug, but you can always have a backup feed just in case.) The HD logo sucks, and they should just tag an "HD" onto the standard Scratch logo for the HD feed. By having USA insert it at their operations they can go back and add the Scratch logo again to the footage when they use it again and they're not stuck with multiple bugs in the future for DVD releases, highlight packages and WWE 24/7.
(Given the way old "WWF" bugs are covered on old footage, you have to assume the bug is on their main master tape of each event.)
post #226 of 572
From the F4W forums:
post #227 of 572
I see what you guys mean about the logos, thats horrible and right in the way of the action. what were they thinking?
post #228 of 572
post #229 of 572
Good lord, even in SD Triple H's entrance has been turned up to 11.
post #230 of 572
btw, thanks for adding the pic
post #231 of 572
Thanks for Maria! The hottest woman on the planet!
post #232 of 572
post #233 of 572
lost signal several times here in PGH via comcast
post #234 of 572
Snitsky in HD = Ewwwwwwwwwwww!
post #235 of 572
What are the F4W forums?
post #236 of 572
Ok here are my thoughts.
PQ is absolutely awful via D*. Terrible motion blocking during non encoder intensive scenes. A freaking sit down interview with Vince should not experience motion blocking when they lean forward or back in their seat. In the ring when they move around it looks equally as bad. I almost expect to see the blocking during the pyro and stuff, but wow, can we say NFL?
3 bugs??? Get rid of the 2 near the middle of the screen. The WWEHD bug is tucked neatly in the the left hand corner.
Sound, pretty good. Good bass.
post #237 of 572
they arent doing 5.1 yet, it was stereo. It will be 5.1 soon (probably for the Rumble) and that should be awesome to hear.
post #238 of 572
They should just get rid of the scratch logo, and just have the WWE HD logo at the top, and that's it.
post #239 of 572
PQ looked pretty damn good on my HR20-700 here...Not sure, but maybe it is something in your setup...
post #240 of 572
It looked good on my HR21 as well. mx6bfast complains about PQ constantly, so I choose to disregard it.
  Back to Forum: HDTV Programming
