I am enjoying my Samsung LN-T4069F
if you want glossy, get the 4071F.
if you want matte Screen, get the 4069F.
Can get them both cheap at Amazon.
If you don't care about the new features of the 69F and 71F.
then get the Samsung 61F, 66F or 65F.
61F is matte screen and 65F/66F is glossy screen.
At your budget, you can even get a 46" for those 3 models at Amazon!
If the room you are going to put the TV on is bright and well lit, many windows, etc: Suggest the Matte Screen.
if you have light control/dark room, or don't mind the glare: Then Glossy screen can be good for you.
Suggest check a showroom to see if you prefer a Matte (non-glossy) or glossy screen.
From my looking around, I find Samsung and Sony makes the best LCD
