AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › I've got 35.5" inches to work with....LCD options??
post #1 of 4
The Amoire that this TV will be going in has 35.5 Horizontal inches of retail space available.. I know...sure any 32" (well not any but 95% of them) will fit with plenty of room. I'd like to know if there is anything bigger available that is worth looking at. HD with tuner are big Pluses!! Other than that....we'll just see what happens!!!
post #2 of 4
I am in a similar situation as you are in except that my Entertainment center has about 37.5" of width for a future HD TV. I have been researching the 37" LCDs and most of them range from 36.1" to 36.5". There are a few that are wider, but they have side mounted speakers.
I think you might have to settle for a 32" LCD.
-Cork55
post #3 of 4
Thanks, Thats what I was thinking....but hoping to avoid!!! LOL Anyone else have anything to offer up?
post #4 of 4
Does anyone have thoughts on the Sony Bravia 37" Rear Projection KDF-37H1000
Looks like this is the only 37" just small enough to fit? Thoughts??? Opinions? Is there another TV out there that will work for my needs?
