AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung 4661 vs 4669 STATIC Contrast Ratio
post #1 of 2
I haven't been able to see the 4661 and 4669 in the same store, so very difficult to compare them, and can't even find the ANSI/static contrast ratio for either.
Today I called Samsung and at least got to level two support, but was told "we don't test for that" and after I pressed more "I don't know, we get asked that a lot but we don't have that information and there's no way you can get it from anyone at Samsung."
So, does anyone know the static CR of either the 4661 or 4669?
Has anyone compared the two side by side and/or own/ed both?
I think I've found out everything else I want to know about the two, but am wondering, based on the 10000 vs 20000 dynamic CR (which so often has little meaning) if there is a dramatic difference between the two in picture quality based on the CR.
Thanks for any insight into the CR questions.
post #2 of 2
To me, the 69 looks better but of course, I don't have them side by side in my home to give you a better answer though.
