Ancient thread yes, but I had the same question. I'm putting together white cables to blend with the wall and at the moment I'm just going to cut the pants as small as possible but finding white ones would be an even better option.
To be honest, I've never seen them in anything other than red or black. Try parts-express, but I don't think they have them in white. If need be use white heatshrink.
Well... red or black white wire pants on a white wall does not make for a classy look if I may say so. I have always just seen those two colors anyways so what I always do is wrap it in white electrical tape. Hehe. Hope that helps.
I've never seen white cable pants. I use a combination of white techflex and white heatshrink to cover my speaker cables. Maybe you could use either or both to cover up the red or black pants.
A small hole just big enough for the wire directly behind the speaker can't be seen at all.
I've never understood why anyone would use wall plates and banana plugs on the wall by every speaker. Just makes for more unnecessary connections, and makes the wire much more noticable.
Just get some white heat-shrink tubing of the appropriate sizes and lengths, and shrink to fit. Just shrink the smaller tubing over the end areas first, and then the larger tubing over all.
Bermuda-shorts length should be about right.
Originally Posted by Seahawk_3 /forum/post/12649459
Does anyone have an idea where I could purchase some white cable/wire pants? All I can find is black or red.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
