AVS › AVS Forum › Video Components › Home Theater Computers › TheaterTek advantages
post #1 of 17
What are some of the advantages (if any) of using TheaterTek for playback in MyMovies over the VMC player with the Nvidia PureVideo Decoder?
post #2 of 17
I am interested in this as well. I purchased a copy of TheaterTek and have been disappointed with it to the point of uninstalling it. It did play DVDs fantastic and lived up to all the hype it has received but I also watch a lot of mkv files. The mkv files would play great but theaterTek would lock up if I hit the skip buttons.
post #3 of 17
Anyone notice that theatertek.com is off the air today......?
post #4 of 17
I have no trouble with mkv files. change the extension to avi and they work fine. Rather than the skip buttons, I tend to press down and then left or right to go forward or back. That seems to work much better than fast forward or rewind.
post #5 of 17
Its up now and was up earlier for me.
post #6 of 17
Theatertek.com is not working for me using IE 7, but it is working with Firefox.
post #7 of 17
Theatertek is pretty awesome if you want a solid, and controllable, DVD player. However, they haven't yet committed, at least publicly, to playing HD DVD or Bluray, which pretty much leaves them wanting IMO.
The only options right now for playing HD stuff are PowerDVD, which is less than marginal, and Arcsoft, which is available right now only in a Japanese version.....
So, we are caught in the middle for the time being, without a Theatertek level solution that plays DVD, HD DVD, and Bluray material. Some folks are using Theatertek for DVD, and PowerDVD only for HD, but IMO, if you have to use PowerDVD at all, and train the family to use it with it's warts, you might as well just use PowerDVD for everything...
Anyway, my extremely frustrated 2 cents...
Mike
post #8 of 17
It's a great program for DVD's but the lack of HD support is a real downer. My guess is that they will fade away since they refuse go give even a hint about any HD upgrade.
That's sad since it has so many great features.
post #9 of 17
TheaterTek works wonderfully for me, well for regular old DVD's...
it is also TCP controllable so it works wonderfully with automation control... try that with win/powerDVD...
as far as HD support goes, Andrew has hinted here and there that when either of the formats actually catch on, that he will look into supporting it/them... but right now, despite the perception of your average AVS'er, there is a higher chance of BluRay/HDDVD going the way of SACD/DVDA then actually making any real dent in the marketplace... yes I know there are still plenty of die hard SACD/DVDA lovers on AVS, but ask some random person on the street and see if they even heard of either SACD/DVDA... HDDVD/BR have much better marketing, but still how many avarage people have actually bought into one format or another? after all, there are only 2 software players out, how long have the HD formats been available... plus, how long before they actually launched did people know about them?
oddly enough, if Andrew (Theatertek) supported one or both of the HD formats directly, I think that would go a long way into move them out of the niche market they are currently languishing in... well it would help at least...
post #10 of 17
What do you mean by pressing down? I am using a harmony 1000 remote. Will this method work for DVDs as well. The problem I have is not remember is the video I am watching is a dvd or mkv file. When I go to skip in a dvd it works fine but if I forget its actually a mkv, it locks up.
post #11 of 17
Thanks, thats what I was looking for.
post #12 of 17
I've got a Harmony 880... On the directional keys, I press down. It shows the movie's timeline. with this on the screen, you should be able to press left or right on the directional pad to go forward and back. pressing down again should clear the timeline display from the screen. Works for both dvd's and mkv's that I change the extension to avi.
post #13 of 17
I just tried that the other day and found PDVD plays DVDs not so well. I don't know if my vision is now spoiled due to HD but DVDs really look bad and out of focus. Do you think PowerDVD's PQ for DVDs is as good as Theatertek? I would be using Vista and an 8600GT card.
post #14 of 17
i was wondeirng can TheaterTek play HD-DVD/Blu-Ray DVD? or not?
post #15 of 17
No, it can only handle standard DVD's. PowerDVD can handle HD material.
post #16 of 17
So what gives a better picture quality: Vista MCE + EVR, or TT + whatever encoder supporting hardware decoding (does it work with EVR?). So assume no ffdshow post-processing basically.
I recently upgraded to Vista so its just not clear to me if there is as much benefit with TT as there was in MCE2005 (which had a horribly soft picture which seems better in Vista).
post #17 of 17
TT 2.6 works nicely with Vista & EVR. I have never compare Vista MC & TT because I was spoiled by how good TT & FFDshow is. The best picture & the easiest control from DVD out there IMO.
