AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Official Logitech Harmony One thread
Official Logitech Harmony One thread - Page 338
post #10111 of 11255
great thanks! Yeah, I only use the HDMI input so this should do the trick.
post #10112 of 11255
Updating Question: I just got my H-One last weekend. I loaded the cd to computer, set it up and programmed from there. I never used or setup my remote at MyHarmony.com . I hear that web setup is best. CAN i transfer my saved setup to MyHarmony.com or did my account auto-populate to MyHarmony.com since i already setup via the CD and updated remote via internet?
I love this this remote. As a longtime user of factory only remotes I was reluctant. The One has exceeded my expectations by a wide margin. I bought open-box at HHGRegg for 107.00 minus a 50.00 giftcard I had... 57 bucks for this??? It's like Hal-109 with a positive attitude!!!!
post #10113 of 11255
MyHarmony.com is AWFUL. Stay with the software. It's not that the software is perfect.. far from it... but MyHarmony is much worse.
Users of remotes such as the 650, that Harmony pushes to MyHarmony but can also use the software, often switch to the software once they come to places such as this and learn that there are not nearly as many limitations in the software as there are in MyHarmony. The switch is not easy, however, as they do not share configurations and there is no transfer mechanism, so each programming method must be configured independently from scratch. The good part of that is that if you REALLY want to try MyHarmony, you can program it independently of the software; if you don't like it you can easily switch back to your existing software based configuration, which will still be there fully intact.
post #10114 of 11255
Panasonic 60st50
when in the menus...lets say adjusting picture settings. left and right double every input. so if the brightness is 50 it will change it to 52 with one click. up and down work fine. oem remote works fine. all other harmony remote functions work fine, doesnt do it for any other device.
thoughts?
thank you.
post #10115 of 11255
Originally Posted by BlouZbee View Post
Panasonic 60st50
thoughts?
thank you.
That is a simple fix
Go to Devices tab
On the TV click "Troubleshoot"
Choose "TV responds to some commands either too many times or only occasionally" (next)
decrease the setting
Save and update remote
post #10116 of 11255
JC, Thanks so much for the quick input. Thats good news because I just need to prioritize to the first screen a few buttons for the bluray and hd dvd player. The software is a bit slow and klunky for speed...but once you are back in the theater....boo yah!
I heard there were server issues which most likely explained trouble connecting on the weekend. Connected quickly today on the first try and updated quickly. Love it.
Edited by Bladerunner1959 - 7/27/12 at 5:21am
post #10117 of 11255
Anyone have the DirecTV HR34 DVR? The One works it just seems laggy and slow compared to the original remote. What settings are people using for this device? I did have mine on default but read somewhere about changing the inter and delay's to 0 which seem a little better at times but still slow.
post #10118 of 11255
I, personally, don't own DirecTV equipment, but this was discussed a few pages back. Have you tried your OEM remote lately to see if it's laggy as well? I understand you said, "...as compared to the original..." but have you compared it lately? Just a thought.
Originally Posted by mdavej View Post
My guess is you has DirecTV. All their DVRs have slowed down recently. I bet the DirecTV remote behaves the same way.
Originally Posted by T_Bro View Post
This is a known issue with Direct TV DVR's. It's not a problem with the remote. D* has informed me they are working on an update to fix the problem. But it seems like it is taking months to get the fix out.
post #10119 of 11255
Yes, the remote is a bit laggy. I have not been able to get rid of that little delay that I don't get with the original remote or the URC 500MX. Still, I have gotten used to it and the functionality of this remote makes up for the annoying lag. IMHO.
post #10120 of 11255
Anyone know how I can use my Harmony One to control two Samsung Tv's in the same room individually? Right now, when I do something on one TV, it also does it on the other.
post #10121 of 11255
Cannot be done. Your best option would be an RF remote that send individual device commands to mini blasters.
post #10122 of 11255
I set up my H1 with my Philips TV (40PFL7705D/F7). Control of the TV worked flawlessly. On my HTPC I have CIR device attached and set up the H1 to send signals. Functionality of WMC works flawlessly. The IR receiver for the HTPC sits atop the TV (I've tried moving it to other locations). When I send an IR blast to the HTPC I lose ALL TV functionality. I mean everything. I cannot use the original remote or the manual buttons on the side of the TV. Nothing functions. If I unplug the TV (the only way to turn it off) and plug it back in, the TV responds normally until I send an IR blast to the PC. After that, I get no TV response although I can still control WMC. Any thoughts?
post #10123 of 11255
^^^ My issue was not H1 related. Does the same thing with the cheap remote I got with the CIR receiver. Looks like my TV's having issues with the signal blasted to the HTPC.
post #10124 of 11255
My Harmony One developed the dreaded swollen battery issue in the last month. I emailed Logitech, and THEY WERE AWESOME!!!!!
Needless to say I am up and running again, quickly, easily and better than I ever imagined.
My question is.......what does the AVS Forum say about charging the remote?? Run it down before charging?? Daily charging?? Leave on cradle when not in use??
I have seen where Logitech says is ok to leave on cradle...but after my issue just wanted to be sure the best way to handle it...........
post #10125 of 11255
I haven't found any consensus here about when and how often to recharge. People have reported both good and bad results from recharging it when it's run down AND from recharging it whenever it's not being actively used.
post #10126 of 11255
I usually use it through out the day or two and charge it to full overnight. So after 1-2 days it drops down to 75-80%. Every 3-4 weeks, I let it drop to 0 and fully charge it to get a full cycle charge.
post #10127 of 11255
Yeah there is not any consensus. You need to find what works well for you.
I have a H1 from 2008 or 2009 with a battery #2 (summer 2011). I still charge it when it needs it, about 1.5 weeks or so. smile.gif
post #10128 of 11255
I have two H-1s, both purchased in 2008. I have always put the remotes back into their chargers when not in use.
post #10129 of 11255
I do the same with my two H1s (2010 and 2011 models) and I haven't noticed any issues with batteries or charging.
post #10130 of 11255
Re-posting this as I saw no response the last time:
I have an issue where I'm not able to control my tv internet streaming services after running the "Watch Internet TV activity", which I had to manually program in. Surely this is a very common activity for most, I simply want to view hulu/netflix/amazon on my Panasonic P60GT50, and run the audio through my Denon 4311.
The activity I programmed in sets everything correctly, except once my tv goes into the internet function, the control pad no longer has control over the TV, so I then have to manually select devices and select tv, which of course makes me lose volume functionality over the denon, which I want.
What do i have to do to retain control over the tv directional pad which maintaining volume control on the AVR?
Jason
post #10131 of 11255
Go to "Customize Buttons" in your activity and choose the tv arrow fuctions for the directional pad.
post #10132 of 11255
thanks! im pretty sure thats what i was missing.
post #10133 of 11255
Only charge it when it needs to be charged. DO NOT leave on the cradle all the time it's not in use. Overnight once a week should suffice.
post #10134 of 11255
Totally worked!
Game changer!
Thank you.
Sent from my GT-N7000 using Tapatalk 2
post #10135 of 11255
FWIW, I cradle my three-year-old One once a week [overnight on Sunday]. I easily get through the week, but I'm not a power user [couple of hours per night]. The battery has been fine so far.
post #10136 of 11255
Sure wish they had engineered the buttosn on the Harmony One to not feel like you're chopping wood.
post #10137 of 11255
hi guys, i use HARMONY REMOTE ONE
is possible to have the discrete code for toshiba ZL1 for
TV (DTT)
HDMI1
HDMI2
HDMI3
HDMI4
I tryed with those but not work ( sorry for my bad english , i'm italian )
Protocol=nec1 Device=64 TV setup code 0156 (10156), 1156, 1256, 1356, 1656, 0765, 0767, 0845, 1711
Device Code: 64 Function: 35 EFC: 219 HDMI 1
0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
Device Code: 64 Function: 36 EFC: 212 HDMI 2
0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
Device Code: 64 Function: 37 EFC: 216 HDMI 3
0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
ANOTHER HDMI3 ?
0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
Device Code: 64 Function: 57 EFC: 025 HDMI 4
0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
Device Code: 64 Function: 61 EFC: 024 Ant/Cable
0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
post #10138 of 11255
Is it possible to have separate user icons/folders/pages (whatever they are called for the One) for favorite channels... i.e. one set for myself, one for the wife and one for our daughter?
I see this functionality with some of the other remotes but I don't see anything on the Logitech site that gives a whole lot of functionality information.
post #10139 of 11255
My 3+ year H1 use to go about a week as well. Now less then 3 days. I always run down my battery even though they say you dont have to. Charge it as you do overnight. Never had the swollen
batery problem. I suppose I could spend the money on a new battery but craddling it when necessary is no big deal. Have to laugh tho at all the buttons that are shedding their black finnish with all the
post #10140 of 11255
Yes... indirectly. You would need to create three separate but nearly identical Watch TV activities. Everything would be identical except the favorite channels programmed in each activity. It's a bit of a pain to set up (especially if you have a lot of custom button programming, but not too bad if you don't), but once its set up switching between the activities is seamless... nothing happens except the favorites lineup changes. Some folks use this to create custom favorites for different household members, others for separate Watch Sports, Watch Movies, etc. with different favorites for each. I have two very similar activities with different favorites... Watch TV and Music Choice. The only differences are the favorites and the remote also sets the AVR modes up for audio in the Music Choice Activity.
  Back to Forum: Remote Control Area
