Originally Posted by lparsons21
I've been fiddling around with equipment today and ran into an issue.
I had a Sony DN1000 AVR in my system and the H1 liked it just fine.
Now I switched a Harman Kardon AVR247 into the rack and the H1 likes most of it!
The part it doesn't like is the up and down control. I tried it with what the database thinks they are, tried it with learning in 'analyze' mode, and lastly learning in 'raw' mode. It matters not!
The only saving grace is that those are not used by me except when I pull up the on-screen display (menu), and I need them to navigate that. At the moment, since I don't really go into the OSD very often, I just use the HK's remote.
Any suggestions? Or is it just the way things are??
I had the AVR347 and it worked fine for me. You could try changing your model # to that one. After you update the model go into devices in the software and change the buttons to "Direction Up" & "Direction Down". For some unknown reason Logitech has the buttons on AV Receivers default to "Tune UP' & "Tune Down". (stupid)
