Originally Posted by BPlayer
When the Dolby indicator goes off, it either indicates that a signal is not being received or the signal is not being interpreted as a Dolby stream. From the symptoms your outlined it appears that the DVR is having some sort of HDMI handshake issue with a display device not being available. Here are some suggestions:
1. Try a different hdmi cable (likely no change, but always best to try)
2. Change the sequence of power on to TV > AVR > DVR or just AVR > DVR
3. Connect a digital cable (coaxial or optical) between the DVR and AVR and use that rather than hdmi when just listening to music. Update the AVR input selection and the H1 software.
1. Cable Works fine 'except' when newly added "Listen to Music" activity is selected FIRST.
2. Audio is fine when "Watch TV' activity is selected (AVR>TV>DVR)
2. a. I tried changing from: AVR > DVR to: DVR > AVR (still skips)
Funny thing is, the problem is ONLY when new "Listen to Music" activity is selected FIRST.
I am wondering if there is a delay I could add after first device (or before 2nd device?) that may solve this. can delays be added?
a) If I 1st select the new activity "Listen to Music" (get skips), THEN select activity "Watch TV" (no skips), THEN select "Listen to Music", I get no skips.
b) Selecting "Watch DVD" activity, THEN changed to "Listen to Music". No skips.
And of course I can manually turn on the AVR and DVR and get no skips as well.
