AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Official Logitech Harmony One thread
Official Logitech Harmony One thread - Page 58
post #1711 of 10746
Could someone please tell me if the Harmony One will work with these devices?
1. Sony BDPS301 BluRay
2. Sony KDL46VL130 Monitor/TV
3. Sony HT-CT100 Receiver/HTIB
Would we lose or have problems with the Bravia Synch Feature by using the Harmony One to control the devices?
Thank you
post #1712 of 10746
Originally Posted by tvmack View Post
You do have my curiosity though why would you want to turn it off ?
I had an 880 for a month because of the price, however, I was never happy with the layout of the remote and returned it when found the deal on eCost.
Anyway, the 880 had this option... and I like it because I move a lot when I'm watching TV, this means moving the remote so I don't kick it or drop it.
Basically, by turning it off I end up saving the battery. Plus... I don't know, maybe it's just a quirk of mine and I just prefer for the remote to turn on when I click a button.
Besides the point though... no big deal, loving the One. Huge improvement over the 880 in my opinion!
post #1713 of 10746
Sorry if I'm mentioning something you already know, but the amount of time that the screen lights up is adjustable. If you're worried about battery life, you can set it to something like 5 seconds, which isn't going to impact battery life much. Combine that with the very good battery life to begin with, and I suspect it'll become a non-issue for you.
Hope this helps.
post #1714 of 10746
Ok, I realize that posting positive things about the Harmony One on this board is preaching to the choir, but for anyone reading along who is on the fence about this remote and has the means to get one, do so. Especially if your reservation is moving from a "macro-based" way of thinking to an "activity-based" way of thinking. I will freely admit that it takes some getting used to, but after a month or so of adapting to Activities I will never go back. If you're hesitant, my advice is to dive right in, but do so with the understanding that it will require a change in "remote philosophy." If you have some trouble at the beginning, read the forums, ask questions here, and be patient. This is just a fabulous remote, and it won't take long until you can't imagine your HT life without it.
post #1715 of 10746
Hope this helps.
Yep, I do know about that option... however, I appreciate the input
And I agree with you. When I got my 880 I was excited but then a little let down with buttons, layout, etc. The One has really made me a happy camper.
I also want to thank squareeyes for his icons, I have downloaded a handful and all my favorites are set up with his icons.
I've been slowly reading thr first pages of this huge thread and see that some usera reported having the Xbox 360 icon buttons (X, Y, A, B) on both the activity they set up and the device.
Can anyone confirm this? I only see them on the activity. When I'm browsing the device directly I get the regular text X, Y, A, and B on the soft keys.
post #1716 of 10746
Graphical buttons only appear in the activities for now.
,R
post #1717 of 10746
Joe, credit goes to saintalan for posting this in a separate thread but i think this would be a good addition to the first page. A/V Control database: LINK
post #1718 of 10746
Is it possible to program a discrete IR code for a device into this remote? I got the IR codes from the product website and it looks something like this:
0000 006c 001b 0000 0064 0064 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0044 0044 0016 0001
Is there anyway to get this programmed into the remote? I can't find anything in the software that would allow me to program anything remotely (no pun) like this. Any help would be greatly appreciated!
post #1719 of 10746
Originally Posted by yngdiego View Post
I'm no Harmony expert, but you can assign an action to a hard or soft button. So if your pause button was an action that paused and turn the lights up, it should be possible.
Hi, this is an older post in this forum, but i was wondering if it's even possible to give two seperate tasks to the same button? If so...how do you do it?
Also, I've done some searching but can't find out how to set "scene 1" or any other scene on the harmony one without the original Lutron remote. I just bought a few spacer system dimmers and want to set up scenes to apply to my activities. How can I set scenes 1-4 without the lutron remote?
Thanks for the help, this thread has already been helpfull for this newbie to set up my HT system.
post #1720 of 10746
I'd like to second this. I grabbed History HD, Discovery HD, and Disney so far. Thanks Squareeyes, nicely done!
post #1721 of 10746
Those look like hex codes. I haven't done it but have read many times that harmony tech support (probably have to go to level 2) can add these.
Go into the activity - customize buttons - add sequence. Name the sequence whatever, then you can add up to 5 commands to that sequence. Then assign that sequence to a button. The sequence can be made of any command from any device in the activity. A simple example would be to assign a pause + lights up sequence to your watch DVD activity. The pause command would be from the DVD player and the lights up command would be from the lutron. Then just assign that sequence to the pause button.
If the lutron remote has commands that didn't get downloaded from harmony, you can go into the device (in the software) and learn the commands using the original remote.
post #1722 of 10746
Call Logitech Harmony support and ask for tier II support. Tell them you have some long hex IR codes that you would like added to your account. They will send you an email. Reply to that email and include the long hex codes along with what device you want them added to, and what you would like them called.
I recently did this to add discreet power on and off to my Toshiba HD-A3. It took a long time to get hold of a tier II support person, but once I did it took about 5 minutes to talk to him and send the emails back and forth. The commands showed up in my account the next morning (I also got an email telling me they were added).
post #1723 of 10746
Gotta tell you - called them and they had it done in a couple of ours - amazing. Great support Logitech!
post #1724 of 10746
I have everything in my appartment programed into my Harmony ONE, except 2 air conditioners I didn't get to yet. Last week my computer crashed, and I lost everything on it, including the Harmony One software.
Can I transfer everything on my ONE back to my computer???How can I get everything I have programed into my Harmony ONE back into my computer???
post #1725 of 10746
You really didn't lose any of the programming, it is all stored on the 'web'. Just download the software from their site, or use your CD, log in with your existing account, and all your commands will be there.
Heck... there's even a website that was used before the software was released.
http://members.harmonyremote.com
post #1726 of 10746
Good Idea!!
post #1727 of 10746
Originally Posted by 120inna55 View Post
Check out the IR2BT. This is apparently a simple, elegant solution. It perfectly reproduces the bluetooth signals of the PS3 media remote, etc. It can turn on/off the PS3 (without any tethered ugly wires). All with one simple, small, unobtrusive, black box. It takes IR (from any remote) and converts it to bluetooth. Unlike some similar devices, this one appears to be immune to PS3 software upgrades which killed the on/off function of other "converters". (Sony would have to do something rendering their own media remote useless for this to happen to the IR2BT). The IR2BT can be powered by USB (by any always-on USB port like on a STB); can be plugged into wall outlet; or can be powered by batteries. Because it transmits bluetooth, it doesn't need to be in proximity to the PS3---you just need to be able to point your IR remote at it.
The problem is the manufacturer is relatively small, so you essentially have to get on a list to receive one. His feedback forum is amazing, though. He (and others) respond quickly, and everyone seems to be quite pleased with the product.
Mine is being shipped as we speak. I can't wait. I know I sound like a fanboy and I admittedly haven't even had the opportunity to use one. I have the Nyko Blu-wave, but I just can't seem to get beyond the delays and the inability to turn on the PS3.
I got my IR2BT last week. It works great with my Harmony 360 remote. I really want the Harmony One but I'm going to wait it out till they have a unit with RF.
post #1728 of 10746
I have had the remote for a month now and still love it!!!!!
post #1729 of 10746
How long does it take for Logitech to add new components to their database? More specifically... The new Sony receivers (ie. 720 series).
post #1730 of 10746
Originally Posted by timick1 View Post
How long does it take for Logitech to add new components to their database? More specifically... The new Sony receivers (ie. 720 series). ...
I got my Pioneer Elite PRO-150 on August 31 - a day before they were released. It was already in the Harmony Data base.
post #1731 of 10746
Sometimes, as long as it takes for a user to put it there!
A lot of devices are there because users add them. I dont know how Logitech work, whether they have manufacturers advise them or what.
post #1732 of 10746
This Harmony One remote looks too good to pass up.
I have a 720 currently (which works great!) but I've never liked the feel of the buttons -- especially the volume/channel up/down buttons.
Anyway... I'd like to get a head-start on snagging some icons. I found a great site for channel icons (from squareeyes) but can't find the A, B, and C buttons that work with a DVR. Any suggestions?
post #1733 of 10746
The A, B, and C button icons show up automatically when you setup the remote. They only show up in an activity not the individual device (I believe).
post #1734 of 10746
Oh, I see. I think.
post #1735 of 10746
Originally Posted by 62thunderbird View Post
Well I did the search and finally found the instructions to add "favorites" and include the icons.
I can't find the instructions.....
Please LINK me.
HH
post #1736 of 10746
Get more familar with the software. It's not rocket science.
post #1737 of 10746
Thank UWE for the help..
HH
post #1738 of 10746
Please LINK me.
HH
HH,
It's down a level in the software.
Go to your Watch TV activity:
-Settings
-Set Up Favorite Channels
Follow the onscreen inst. from there. Use 'Browse' if you want to add icons that you have downloaded to your computer.
Or you can use any of those fantastic 'Fox' affiliate icons that Harmony has set up for you...
Hope that helps.
,R
post #1739 of 10746
Originally Posted by squareeyes View Post
HH,
-Settings
Hope that helps.
,R
Thanks S-E
I tried the search and kept getting everything but what I needed.
Now,,,Off to use Your icons.
HH
post #1740 of 10746
That would be one rocket scientist to ... Oh, wait. SC lol
  Back to Forum: Remote Control Area
