Originally Posted by
jdryyz
I received my Harmony One yesterday. Setup was a breeze. Only minor corrections were necessary. I was amazed at how well the initial setup worked. Since then I have been doing even more tweaking and adding more activities for my various devices. It is shaping up very nicely.
A few problems remain:
1) When I switch to "Watch Blu-Ray" after leaving my "Watch HD-DVD" activity, the HD-DVD player remains on, even though I specifically set it to turn other devices off. This only happens in this sequence. Switching to and from other activities *does* turn the other devices off.
My guess is you have the HD DVD player set up to send the play command when you start the activity and the stop command when you leave the activity. It is sending out the stop command and your HD DVD player takes too long to stop playback, so it doesn't recognize the PowerOff command. Go to your HD DVD activity and click on more options. There should be options for send play on start and send stop on exit. Turn both of those options off and it will probably take care of this issue.
jdryyz
2) When switch to any activity, I would like the display to switch immediately to the activity buttons instead of asking if I need help. I did turn this option off for each activity, but it still pops-up on some.
Sounds like you've already got this fixed, but just in case. There are 2 ways to turn off the remote assistant. One is in the options page on the remote itself. This will only turn off the remote assistant until you do the next update, then you will have to turn it off again as the software still thinks you want it on. The other way is to turn it off in the software, that way it will stay off unless you turn it back on in the remote settings, or in the software again.
jdryyz
3) My activity icons do not match the activity in some cases (I have a Laserdisc icon for my BD player). If I could change this to a DVD icon, that would be fine. Even better would be to change it to a Blu-Ray icon. I understand this is a popular request, however, and there are none available at this time.
When you first start setting up a watch a DVD activity it will ask you if you want to create a watch a DVD activity, a watch a Laserdisc activity, or someting else (watch media center I think). You probably picked watch a Laserdisc by accident. You can delete that activity and start over again, or I think you can click on the activity and tell it to go through the setup again to change it. At this time there is no watch a Blu Ray option, but it wouldn't suprise me if they add one eventually with the Blu Ray icon.
