Originally Posted by Chris Gerhard
This can't be a remote issue other than it may be that it is sending an unwanted signal to your equipment at some point. Are you sure you still have the correct input selected for the display? The answer is you should not have to do anything differently to play DVD or Blu-ray from the same player. What player are you using and which display input? My guess is you will have this fixed before you come back to see answers.
Chris
Chris
It's a sony BDP-S350 and it is directly hooked to the TV via HDMI1. When the message 'no input signal' displays it does show the correct input.
I wish I could solve it that quickly. I spent about 2 hours messing with it on Sunday.
You might have a point about it sending an unwanted signal. I say that because, after I have tried to play a blu ray disc with the hramony one, I went back to play the blu ray with the original remote(I turned everything off before I did this). Then I got the same problem as w/the harmony one. I went into the setup/settings of the blu ray and reset to factory defaults, then I tried to play a blu ray with the original remote & everything worked fine (wierd?). Can it be possible that the harmony one sends something to the blu ray which causes the settings to change on the blu ray player?
