Originally Posted by JimInPT
I've read the entire thread and haven't found this problem (hope I didn't miss it).
I'm trying to get my H1 set up for Favorite Channels. Have successfully added one so far, CBS-HD, with one of Squareeyes' beautiful icons into my Panasonic plasma TH-58PZ750U.
But I'm using basic cable, with no cable box, and much prefer it that way because I hate the boxes. The HD channels on my system are up in the 72-x range (CBS on 72-1, ABC on 72-2 etc.) and I can't seem to figure out how to enter the minus/dash symbol into the H1's Channel number box in Favorite Channels.
The key is "Prog-" on the remote, and so 72-2 would be entered as "7 2 Prog- 2" on the TV's own remote control.
If I enter 72 by itself, the Panny defaults to 72-1, that's how I got CBS working, but I need help programming the H1 to accept the dash symbol to access the others.
Thanks, gang; loving this H1 after just two days. Don't forget to donate to the Squareeyes icon bandwidth fund here.
This is how I overcame entering OTA QAM channels on the H1:
I was having this issue with my H1: couldn't locate an option in the desktop software interface to select a dash or a dot for HD OTA subchannels.
SOLUTION:
Using the device "Learn infrared commands",
Verify the column name to see if the . or the - is already defined (will say under Database in the Origin column).
If already defined, then test it in Device Mode.
If it works, then use it in the "Set Up Favorite Channels".
Else, decide which one to use (. or -),
Then using the learning process (using the device "Learn infrared commands) teach the dash command from your original to the command named . or -.
If the . or - is already listed in the column name, then select it,
else type the . or - (single character) in the "MyNewCommand" box at the bottom & teach the dash or hyphen to your remote.
Follow usual steps to assign buttons to your new dash option.
Then assign to your favorite channel.
