Originally Posted by
oman321
OK, I'll explain further since you keep it on the same input.
You'll need to set the tv device up again. A couple clicks into setting up the tv device the software will ask you how you select inputs. You will need to select the option that says I press a button to bring up the menus and then scroll to select input. Option 3 I believe.
The next screen should then list the inputs, which you will need to re-name to match all of your available scenes.
The next screen should ask if your device skips unused inputs, say no.
The next screen is where you instruct the button presses you need:
Option 1: Remote button displays source inputs menu
Select command that brings up the scene menu
Option 2: Remote button cycles through source inputs
Button that moves you from one item to the next, probably down
Options 3: Remote button confirms the source input
Button that selects scene, ok or enter perhaps.
Next screen should be no
Then the next selection should be
Stays on whatever it was on when it was turned off.
After this it should be whatever your tv is setup as. Continue to go thru the wizard and finish the setup.
You then need to redo your activities, to have the input selection on each activity be the scene selection instead. So you will indicate that you do switch inputs when going thru the activity, this should now be your scene selections.
When you switch activities the harmony will believe it is switching your inputs and keep track of the last input/scene the tv was on and will change accordingly when switching activities.
This makes sense in my mind and should hopefully work out for you. Let me know if you try it and how you make out. We can go from there.
