TPETERSON - My mother board is an Intel D845PEBT2 with the Intel 845PE Chipset. It has an Intel P4 2.4 CPU with 533MHZ, hyper-threading and a 478 pin socket. It was a rather popular board at the time, since it was the first that Intel ever came out with that allowed you limited overclocking. As for memory I have 1.5 Meg of Crucial memory. It has 3 IDE HD's, one main (C) 300Gig, Master and an 80 gig (slave) that is used for Acronis back-up. Both of those are on the Primary IDE. The Secondary IDE has a 160 Gig HD (master) that is used for writting videos to, and DVD burner is the slave. The only other card in the system is the ATI Radeon 9550 vidoe board which is in the AGP slot.
JLDET5 - You may have valid point. My XP is set to reboot. I must say that it has never done it before on any program I have ever used, but software and drivers are a major cause of systems rebooting. Since this only happens when I'm running the DIVCO software, I have to believe that either the software or a driver is causing it.
It doesn't seem to matter what stations I'm watching it on. Last night the station I was watching, when it went for over 2 hours before rebooting had a signal strenght of 100%, since it's the closest to us. SS doesn't seem to be a factor. If a station's signal is too weak, it will just sit there with with a blank screen or change to another.
Now the one time it did give me the BSOD, the message was: "ATI2dvag device driver got stuck in an infininate loop". Possibly, this could be a problem with the ATI video board's drivers. I did upgrade to their latest drivers, after removing all ATI programs/items left over from my old ATI HDTV board and all the programs/drivers for the ATI video board needed to be reloaded, so I got the latest one available. I never thought about that possibly being the cause, since it works so well otherwise. I might try watching a movie or video I have on the computer, since I have removed the Fusion board from the computer and see if it acts up again.
