As the title suggests, I'm starting my theater. It will be a long process made up of two relatively short phases.
Below I’ve broken down some basic info. I really need feedback on my decisions, but more importantly I need answers to my questions and feedback on my fears.
All comments and suggestions are welcome. Thanks in advance for your help. Construction may begin within a month…
What I know for sure:
Decisions not yet made:
Biggest fears:
I'm reserving the rest of the space below on this first post to display pictures of the current progress.
Progress report:
Thread Started on AVSForum
First Diagram of room started
Construction Begins
Electric run
AV cables run
Conduit to Projector put in
Drywall hung
Drywall Tape and Mud (screenwall shown below)
Drywall finished
Trim and doors installed
Walls painted
Carpet installed
Speakers 20 inch computer monitor, reciever, and xbox installed.
- Room Construction
- Equipment Purchase and installation (at least one year later)
- Concrete walls and steps will limit the room to 19 x 14 x 9 BEFORE studs and drywall. I’ve added a diagram below of what I believe are the max dimensions of the theater once studs are up.
- Equipment will not be in the theater (although may be accessible from the theater). In other words I won’t have an equipment rack sitting in the room somewhere.
- Room will be built at least 1 year before any theater equipment makes it in there. I’ll probably use it for an office with a two channel (Klipsch RF-3 tower speakers) setup, but may leave it empty… which will most likely encourage us to finish the room.
- While someone else will be doing the labor (putting up the walls, hanging drywall, wiring the power), the rest will be up to me. However, I will not be hiring a specialist or using my local shops (actually shop unless you count magnolia in Best Buy - which I don’t), because I have no confidence in them or any desire to spend money on knowledge that can be gained from research. Besides doing the design myself is half the fun.
- This will not be a showplace as it is HT 1.0. Instead I’m looking to put money into what I can take with me when I leave the house, or what will add the most performance to the room. In other words, no fiber optic lighting, no wood columns, no hidden speakers, no fake front wall.
- Room will be used for 30/30/30/10 (movies, gaming, television, other)
- Fixed screen attached to wall (I could be talked into juts painting a screen if I believe it will save money but still allow for really good performance, but I’d rather have a real screen.)
- In room speakers
- 7.1 channel system
- Center below the screen on stand away from front wall.
- Two rows of 3 seats
- Back row on riser
- 16X9 screen (Update - this decision is now about 50/50 for a wider screen ratio)
- 1080p projector
- 92 inch screen (only because everything I read suggests I can’t go larger and still be reasonable on size – please convince me otherwise). EDIT: According to THX, I can go up to at least 116 and still be ok!
- Two doors in room. One for accessing the room, and one for accessing some utilities pipes on side of room (see drawing ).
- I plan on using an existing Definitive technology PF1500 subwoofer
- I do not plan on using my Klipsch Reference speakers once the equipment purchases begin EDIT: I'm rethinking this for HT 1.0. Right now I already have the front 3 speakers and could simply add the back 4. This would be much cheaper than buying 7 new speakers. Also, I think Klipsch are pretty good speakers for movies. They are very dynamic, efficient, and detailed. So while they aren't my first choice, sticking with what I already have may speed up my purchases in other areas.
- Do I make equipment accessible from the theater? I’m worried that making it accessible opens a hole in my wall which will allow sound to travel outside of my theater, but I also don’t want to have to go into another room to change movies or Xbox games (neither is a huge concern, but seems silly to walk into another room to make this change and it would be a huge pain to explain this to my wife). EDIT: Decision made - Equipment will not be accessible from room.
- Where to put the equipment – under stairs or in own room off the theater. Under stairs means it gets more ventilation, own room means more accessible if not accessible through theater. EDIt: Decision made - Equipment will sit in the room to the side of the theater. This will allow for easy access from the theater to change movies or games. However, I planning on using an IR repeater or RF (even better) system to controll everything so that it does not have to be seen in the room.
- Should I use Green Glue? EDIT: Decision Made - I will not be using GG
- Should I use two layers of drywall? EDIT: Decision Made - I will not use 2 layers of drywall. I feel that using GG and 2 layers will most likely not give me the results of total silence outside the room. Instead I'm treating my wifes ears with a noisemaker (fan) in our room so that when I turn the music up she can simply mask the sound - fix = $20 If at some point I decide this was a major mistake, I can always add another layer of drywall with GG... although that is doubtful.
- Should I do a stage? EDIT: Decision Made - no stage. We've decided that this room needs to be set up genericly so that our potential buyers aren't turned off by a dedicated room. If they want to dedicate it, it will be simple, but if they want to put a pool table in there, they won't have to deal with a stage and riser.
- Should I mount my projector to the ceiling or on a shelf in the back of the room?
- Should I build a hush box for my projector?
- What kind of conduit is best for cables in case I want to run a new cable to my projector or another area in the theater at a later date?
- If I need an HDMI cable that is about 40ft or less, is there anything special I need to look for, or will something simple from monoprice do the job? EDIT: Decision made - 1 35' HDMI cable purchased from Monoprice
- Where should I put the Subwoofer?
- Should I use two Subwoofers?
- What should I do about lighting? EDIT: Decision Made - 8 cans 2 on each switch (will not use graphic eye at this time, though may try and get one later)
- If I do two layers of drywall, what thickness should I use? EDIT: Decision Made - Not using two layers
- Should I use special drywall (Quiet Rock), or just standard drywall? EDIT: Decision Made - Using standard drywall
Biggest fears:
- I’m very concerned about isolating the sound in this room. While it sits under my dining room, any amount of noise out of this room could wake up my wife who essentially sleeps with one eye open…
- I’m very worried about HVAC. The space currently has a single vent in it. My unfinished basement is wide open (1400sq ft) and is on average 5 degrees colder than the first floor of my house.
- Room acoustics. I really want this room to sound as good as it can (within reason), and know that it will require some room treatments.
- Budget – This is HT 1.0 for me. We will most likely move from this house in 5 years and therefore I have no desire to dump 50 grand into this room as little of that would ever come back to me in our market. I want this room to be like a Camaro – Lots of performance, quality is good and nice to look at but no Ferrari, and therefore reasonably priced.
- Time – we’ve decided to start finishing the basement in the next few months (possibly within a month). I want to ensure that this room is set up for flexibility and quality now, so that when I start buying equipment I can simply plug and play.
Progress report:
Construction Begins
Electric run
AV cables run
Drywall hung
Drywall finished
Walls painted
Carpet installed
