So I'm in the midst of building a HTPC. Vista Home Premium is already on order as is the MCE remote. I already have the gaming PC acting as a Hybrid HTPC as well, until I can get a dedicated one going.
However, I'm very much interested in buiding a NAS. Originally I turned my head to it as it can get expensive. However, the mroe I think about it; it's not ALL that bad. I AM looking for a budget build, however, I won't skimp to much on parts as I want it to be functional instead of a POS/waste of money.
I'm torn however, between a RAID 5 array and unRAID. First I was highly leaning towards unRAID as it's less expensive and I can use old IDE drives for the time being. However, I've read from some that it's not all that it's hyped up to be, and that RAID 5 IS better...opinions?
Also, whether I go RAID 5 with Windows Server 2003 or I go unRAID...what type of horsepower do I need to run the NAS? I was initially thinking a cheap P4 or AMD 64 solution. Single core, 1GB RAM, integrated sound, possibly integrated video and a 500W OCZ power supply. Would this be enough? I was thinking along the lines of a AMD 64 3500+ (or eqivalent) or a P4 2.0Ghz. Could that handle the serving appropriately?
I already have Windows Server 2003 so that's not an issue should I be forced to go RAID 5. I also already have a Lian-Li PC-65 that I can convert into a storage case via Lian-Li hard disk 5.25" conversions (or backplanes).
I looking at eventually having around 1.5-2TB if not more @ about 6-10 HDD (if that).
Suggestions?
Suggestions?
, but prob for me, since i dunno anything about linux.
This is a NAS, there should be no KB/Mouse/Monitor even connected to it after the initial install. (caveat: Make sure any motherboard you choose can boot without a keyboard, or atleast will let you bypass the KB error when POSTing).
