AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Cup Holder Solution for Current Chairs
post #1 of 51
I'm not sure if it's best to place this question in the Dedicated Theater thread or the Accessories thread. I thought I'd try here first since it's part of a dedicated theater.
I'm trying to figure out a way that I can incorporate Cup Holders for my viewers (6 seats). I had an original idea of using some MDF and making something that would slide over the two butting arm rests.
My buddy then reminded me that my Berklines (cheap ones from Best Buy a few years back) are somewhat narrow, and may make for an uncomfortable seating arrangement with these over the arm rests. I may make one just to see, but I expect the center chairs in each row to be too narrow since there would be a holder on each side of the arm rests. Does anyone have any other solutions that I could possibly tackle? It's getting old that we have to keep our soft drink bottles between our legs during a movie. Here is a pic of the chairs.
post #2 of 51
It looks like you have some play with your seating why not do what your thinking but just move the chairs apart about 6"-8" and build a box to go in between the seats. You could even cover the box with some cherry or oak veneer and really make them look nice. I'm sure others will have some good idea's
post #3 of 51
That a good idea WOOlly,
I would build it just wide enough for a cupholder, but from front to back of the seat. This way you could put two cupholders one behind the other in each section. One on either side of the center seats. This way you'll have 4 cupholders available, maybe make it big enough for popcorn cups too.
post #4 of 51
I have a similar issue in my theater, some thoughts I have had about cupholders: They do not necessarily have to go over the armrests, you can put a "drink stand" just in front of the armrests/chair faces and leave the chairs pushed together. You could move the chairs apart about an inch, and put a 1" pole or 1" board coming up from the floor to 6" above the height of the arm rests, and mount your holders there, so you don't lose the armrest (hope that makes sense). That one might look a little funky, but it should not block any sightlines.
post #5 of 51
I bolted some black cup holders made to go into a window of an automobile to the fronts of my arm rests. Came out mighty fine.
post #6 of 51
Now that's an idea I hadn't thought of. I do have the room to do this. That wouldn't be very difficult to construct either.
I'd have to do some measurements, but maybe route out a rectangular inset to the top of the box where the Popcorn cups could rest, with Cup holders on each end of the box. I like constructing things, but don't have all the tools. But I have several family members that build houses, cabinets, furniture, etc. where I could obtain some help (i.e. borrow tools).
That is one that I did think of and have drawn up. After hearing the thought about the box between each chair, I'm really liking that approach, if I have the room...will have to measure. I remember seeing someone's thread somewhere on this forum a year or two, or maybe even three where they used PVC pipe to make cup holders between chairs. I couldn't find it when searching. I should search the archives.
I love this thread. You guys rock. What a great idea!! How hard is it to do this? Can you give me a description of how you accomplished this? I wouldn't want to rip the leather on the front of the chair by drilling into it. I mean, I don't want it to tear and then get bigger, etc. Did you drill a pilot hole, then drill in screw/bolt with washer, or use smaller screws? I'd love to see a picture of this. This sounds like it could be the cleanest look. My children are 3 and 5. When they are in the theater, they like to jump off the chairs. I can see them ripping these off, but I'd just be sure to inform them not to play rough near the chairs. Really though...pictures?
post #7 of 51
OK... I really need to get pics of my stuff or quit postng on here....
Mine were microfiber and cheap as hell, I'm not so sure I'd do this to leather. I wonder if hot glue would be better on leather? As long as it held.
I just put the cup holder against the arm rest, drilled small pilot holes then wood screwed them with the cordless w/phillips bit and used flat washers. I only did two cup holders for each set of three seats.
post #8 of 51
Ask and you shall receive - pic courtesy of member scottyb.
post #9 of 51
tony
I think the box approach will probably be the easiest to do and if you don't like them just remove them like a piece of furniture
I did a search for some drop in cup holders
http://www.txpokersupply.com/table_hardware.htm
http://www.stargatecinema.com/Berkli...-pr-17618.html
http://shopping.rexmar.com/Merchant2...FQ2aOAodVgSkXQ
post #10 of 51
That's it. This would be the easiest I think. The tables would be the best looking.
post #11 of 51
tony
Thanks!!! I talked to my wife. As far as the looks, she likes the table idea too.
post #12 of 51
I'd have to measure and make sure this would work as far as the size of the box. If not, I could take it down to one popcorn holder. This is really simple, but may look nice between each of the chairs.
post #13 of 51
I agree that the aesthetics leave a lot to be desired on that design, but I like the concept of a support that is very small/thin if you have width issues. Using black poles and holders would go a long way. Just one way to go - either between seating or just in front with a Y piece for dual holders.
post #14 of 51
I like it TB,
Might be uncomfortable reaching for the rear drink though depending on the depth (if you go to the back of the seat). You might try to model it with the two cupholders up front and the you'll probably still have space for the popcorn at about midway. Either way it's looking good.
Come to think of it you might consider a hybrid of the ideas being given. You could also attach the PVC cupholders to the front of the table unit with, the popcorn slots up front. Good luck.
post #15 of 51
I like it TB,
My friend said the same thing as you regarding the placement of the cup holders. He also felt it may be to cumbersome to reach in the back for the drink. My wife and I, in the car, tend to have issues with grabbing the wrong coke or water out of the center console cup holders unless we are looking directly at them. That was my only fear with placing both of them at the front of the table. Still not out of the question. Need to do some measuring. Most folks recline in the chairs, so that would make it a little easier to grab the drink in the back. The hybrid idea is an option. At least now I have some great ideas to play with. Thanks.
post #16 of 51
We just thought about this ourselves, and voila!
Works fine or us.....
And you can move 'em anywhere...
Best,
Tom
Chinaclipper
post #17 of 51
Tony, I'll be building tables with cupholders for between my chairs too. We can build them together out in my shop. I'll be building mine very similar to your design in post 12. You'll need 4, I need 3, though the one I'll be putting in the back will be much more complicated than the front two. Get in touch and we can schedule a a weekend to knock them out.
Chip
post #18 of 51
Just a tip. My company has used the black plastic cup holders for years. We started using stainless a while back. Paper and plastic cups condensate on the outside. The moisture makes the plastic cup holders stick to the cups and pulls them out, when you lift a drink up. Either glue the plastic ones in with PL400 etc... or use the stainless. If gluing, remember you cant take them out to clean them, something you might regret down the road.....
post #19 of 51
Ross, Great tip! I was planning on stainless anyway, but you confirm it's worth the extra $.
Chip
post #20 of 51
tony
Get yourself some scrap Plywood and do a mock up first that way if you don't like it or want to reconfigure it will not cost you anything.
Happy building
post #21 of 51
I think it was Swithey who made some very nice cupholders.
I'll try to find the link.
Here you go....more info in his thread.
http://avsforum.com/avs-vb/showthrea...17#post9503317
post #22 of 51
Brian if you read on swithey scraped that idea and bought those little tables. Tony that mite be something to look into then you would not have to build anything
http://www.eurway.com/tables.lasso?i...0918xKp391D8AF
post #23 of 51
Yeah, he did scrap it, but if you wanted something that wouldn't encumber on the seating space those tables would work. Use the chair to hold the back of the table down.
Anyway, its another option. Thanks to the fine folks here, you've got a couple different paths you could go down.
post #24 of 51
Chip
Cool Chip. I'll give you a ring next week and we can set something up. What are you planning on building yours with? I was thinking of MDF, but not sure that's the best option. It seems most the cup holders I've seen are around 3" in diamater, but I'd like something a little bigger. Do they make bigger cup holders that will hold large size cups and bottles? Have you laid out a design for yours yet?
post #25 of 51
I could probably build something that would be a little cheaper per stand than those. I'll have to price it out and see. I do like the looks of that glass table though. With the thin pole, you'd lose little width of the room as well.
post #26 of 51
Nothing on paper, just in my head. I generally don't put anything on paper until I need/have final dimensions. Seems once I put something on paper the creativity stops and designs do not evolve anymore.
Chip
post #27 of 51
OK here's the scoop on this cup holder.
I stole the idea from another member but don't remember his name.
I enhanced it though.
Instead of the total build and screwing the holder to the floor I put a 25lb weight plate on the bottom of the the pipe. This way you can move them as neccessary and vacuume under them. The reason for the heavy weight is to prevent them from being knocked over. I painted the whole thing black and it looks great.
I also invented a variation on the same plan by putting a T at the the top of the floor pipe and then put two elbow pipes and then went to the cup holder so you get two holders in between or in front of two chairs. I'll try to figure how to take a pic and post.
It sounds like this thread is going a different direction but I thought I'd post for others when they do a search.
These have helped the function of my theater a lot.
Tables are too easy to have the beverage knocked off, be it a kid or an adult.
Feel free to ask any questions and I'll try to get a pic soon.
Scott
post #28 of 51
tonybradley,
acutually after looking at your seating these would be perfect for you as you could keep your seats very close together.
If you want to go this direction send me a PM and I'll send you my number.
scott
post #29 of 51
You can get inserts for Berklines in AL in Black or Silver. Maybe you could insert them in the arms.
post #30 of 51
First time to load pics, we'll see if I did it right.
[/IMG]
[/IMG]
