Originally Posted by cloneranger
I realize that this discussion took place almost a year ago, however, I recently acquired a Comcast DVR (Motorola DCX-3500) and entered the 21st Century. Being technically inclined (a web developer by day), I figured it can't be that difficult to archive HD recordings from the DVR. At 2 - 3 Gigs a pop, it doesn't take long to fill up a 250 GB drive. As an avid F1 fan since the late 90's I was hoping to transfer my collection of VHS tapes to digital storage, they're taking up too much space and deteriorating fast.
Needless to say I am finding the apparent lack of support on behalf of the manufacturers quite disappointing. It's possible that the lack luster support may stem from concerns of not wanting aid or abet piracy, however, since those who are so inclined will probably find a way anyway, better support should be available for those who wish to archive legally.
Anyway, so I've got this DCX-3500 connected to a Dell GX-270 running Win7 and can't seem to find the right AV/C Panel driver. Any help would be much appreciated. Not sure if anyone's still interested in the Hardware ID's but here they are just in case:
AVC\\MOTOROLA&DCX-3500&TYP_9&ID_0
While researching possible solutions to the DVR archiving issue and anticipating that the DVR to PC solution might take a while, I came across and decided to try a Vulkano Blast from Monsoon Multimedia. There's a noticeable drop in picture quality (on a 60 wide-screen) but it's still acceptable and the quality is excellent on iPhone and iPad. The Blast supports remote viewing of live TV, scheduling recordings and transfer to the remote device for instant, none network dependent viewing. I'm pretty impressed with it but if possible, would still like to store the rounds of this year's F1 championship in full 1080p, HD quality.
There is a dedicated thread about FireWire capture from Motorola set top boxes here with some good info:
http://www.avsforum.com/avs-vb/showt...php?p=21949917
Two important things to know before you dig much deeper though:
1) There are no 64-bit Windows drivers for the Motorola boxes , so you must use a 32-bit Windows installation in order to capture from your STB.
2) The FireWire capture functionality on the DCX boxes is buggy and transfers are not reliable. I have done successfully many times but I usually have to make at least two transfers, run a utility to detect errors and then edit two or more passes together to get a clean recording free of errors. I use VideoRedo to do this, one of the few tools that can do frame by frame editing of an MPEG2 stream natively. It's a pretty tedious process, though the editing process also accomplishes the goal of removing commercials, which typically reduces storage space by about it 30%.
