Originally Posted by
Jerbo
If the power sequencing work around does not work (I read in another post that this works well for Yamaha AVRs but not for Denons)
I suspect the reason for this may be your mention that you have your "standby HDMI pass-through" enabled, even though you have no reason to. I suspect that setting may be the Denon default and you actually have to disable it if you don't want to make use of it.
If this "standby HDM pass-through" is enabled, then it doesn't make any difference whether the Denon is off or on... the HDMI pass-through will effectively defeat the intended result of "AVR on last, AVR off first". Essentially the AVR is always on, no matter whether you think it's being turned on/off first or last or whatever.
It's certainly worth a try here, to disable "standby HDMI pass-through" and then see if "AVR on last, AVR off first" will preserve your "native" sttings on the DCX. I know that trick worked fine with my Yamaha RX-V863 when I actually had a DCX box, in that "native" WAS preserved. Never needed to reset it (except if I accidentally forgot the power sequence when turning things on or off). I needed to go through the AVR and didn't really have the other option available (of HDMI from DCX to HDTV and optical from DCX to AVR) because my Sony 34XBR960 HDTV only has one HDMI input, so it naturally had to come from the Yamaha in order for me to handle all of my HDMI source devices with my single-HDMI-input XBR960 .
then I'll try the optical cable for audio. While I concede all your points about HDMI dd 5.1 being equivalent to optical dd 5.1 with no handshake issues, it would require me to reconfigure my system somewhat
The Yamaha AVR's are very easily configurable using the "manual input" menu. You can configure any input (i.e. a source button on the remote) to specify whether its input uses which of the available HDMI, component, optical, or coax inputs. You can mix and match any way you want and pushing that source device input button on the remote then automatically makes use of whatever inputs you've specified. It's invisible that you're using optical delivery for DD5.1 instead of receiving DD5.1 via HDMI, and the audio results are 100% identical.
If I may, a couple of final questions:
1. Is my assumption correct that there are no discrete On / off commands for the DCX? I haven't researched it.
Correct. The Motorola boxes have a simple "power on/off toggle" when you push the power button on either the remote or the face of the unit.
2. I assume the DCX even when off will wake up to record my scheduled programs.
Absolutely. If it's off when the scheduled recording time arrives it will power on automatically (with audio in MUTE mode, just in case your sound system happens to be on) and the recording will be performed. The unit will then go back to sleep when the scheduled recording(s) are completed.
Note that if you walk up to the unit when such a timer-initiated wake-up/record is going on and audio is in MUTE, if you push any button on the remote the audio will be un-muted. The box now knows a human is in the vicinity and you may want to watch some other program (live or recorded) while the timer recording is going on. If the foreground tuner happens to have been acquired for the recording you can just push the SWAP button on the remote to flip the background/foreground tuners, which will push the scheduled recording tuner into the background (where it will continue to record) while the other DCX tuner is now available for you in the foreground to do whatever you want. Or, you can simply play a previous recording in the foreground (which doesn't actually use a tuner) while the scheduled recording tuner continues to work unattended in the background.
Also note that in addition to un-muting the audio when you push any button, you've also just deactivated the "automatically go back to sleep" function when that scheduled timer recording completes. Again, the unit knows a human is in the vicinity and watching TV or something, and turning the unit off when the background recording completes would be very annoying.
But assuming the box will NOT self power-off after the recording process completes
This is not true, as long as you don't interfere with the automatic process of wake-up for scheduled recording by pushing a remote button during the unattended operation (say a recording scheduled for the middle of the night when you are not in the room using the DVR). It actually WILL self power-off and go back to sleep in this case.
Only if you push a button will (a) audio un-mute, and (b) self power-off at the end of the scheduled recording is disabled.
will this cause any handshake issues or new complications?
You mean from the unfortunate HDMI handshake going through the AVR? Again, that's why you should turn off the AVR when not in use, and you should not have "standby HDMI pass-through" enabled on the AVR, just to guarantee no unexpected HDMI handshake complications. Or... just connect the DCX directly to your HDTV (which should also be powered off when not in use) via HDMI and use optical for audio.
3. As I'm typing all this, I can foresee the remote control macro programming process being quite cumbersome (assuming no discrete on / off for the DCX).
Well, for some the "toggle power on/off" is a convenience and a discrete on/off (as there is for the Yamaha RX-V963 which actually has two separate buttons on the remote) would be a nuisance (as it is for me). Most ordinary multi-device remotes have a simple device-select collection of buttons, and one POWER button. The theory is that all devices have a power on/off toggle, so I can only program my multi-device remote to be able to power OFF the Yamaha, not to also be able to power it ON (which I thus have to do myself).
Maybe I should just suck it up and run the damn optical audio out to AVR and HDMI direct to TV.
I rest my case on this one.
Am I the only one who "feels like" the audio from the HDMI connection sounds better than that via digital optical? (yes, it is not LPCM coming thru optical, I've verified it is dd 5.1). I have no reason to question DSperber's contention that the two connection methods for audio are identical.
It is the bitstream-identical DD5.1 (from the TV program) which is being delivered from DCX to the AVR, no matter whether it's going over HDMI or optical.
Note that the "LPCM" audio setting on the DCX (additional HDMI options) is not true multi-channel discrete LPCM (as it IS implemented say on the Oppo BluRay players) sent out over HDMI. In fact, if you choose "LPCM" on the DCX you're forcing 2-channel stereo audio out over HDMI. This isn't what you want, obviously. Just let it send DD5.1 to your Denon and let the decoding occur in the AVR. There is no difference in audio result where this DD decoding occurs, and this is the right way to deliver HDTV multi-channel audio to your sound system... by letting the AVR do the decoding.
And as I mentioned earlier, the "additional HDMI options" only affect HDMI connections. In contrast, digital audio going out over optical is ALWAYS THE ACTUAL DIGITAL AUDIO BITSTREAM IN THE HDTV PROGRAM... whatever it is, DD5.1 or DD2.0. The optical audio path is completely unaffected by the "additional HDMI options" for audio. That's another reason why this is advantageous, since the HDMI-visibility of your HDTV to the DCX can thus never cause the DCX to drop down and deliver only 2-channel stereo over optical (as it can over HDMI).
While your video may definitely look different (i.e. better) on your display when digital HDTV video is delivered via HDMI (which is digital) vs. component video (which is analog, and thus involves probably two conversions when going from the the original digital program content to your HDTV screen first via analog component video and then back to digital for display by your pixel-based HDTV), I can assure you that there is ZERO DIFFERENCE in sound for digital audio from the two different cable delivery methods.
I also would not think I have any reason to question the integrity of my Denon 3311ci AVR's ability to process Dolby digital equivalently whether receiving the signal via HDMI vs optical.
This is a fact.
Edited by DSperber - 9/9/12 at 8:22pm
