Last week I bought the A3 at Best Buy for $175 (12% discount).
I immediately bought the Planet Earth from Amazon (and watched tonight), 5 movies (Buy 3 get 2 free at BB - bought today), sent off the 5 free HD DVD receipt, and watched the 300 and Bourne Identity that came with it.
At this point is it worth hanging on to the HD DVD player - at the price I got it at - and continuing to buy HD DVD movies (fire sale)? Will the HD DVD movies go the way of the dinosaur, or might they still be playable on a combo player down the line if I continue to buy them?
Or would that be stupid because once my HD DVD player died, the movies would most likely be useless?
Or should I just return everything (Best Buy said they would take the DVD player as a return tonight when I called them - *not sure about the 2 movies that came with it that are opened?). I can still return the 5 other movies because they are unopened. Should I then take that $$$ and roll it into a (gulp) Blue Ray?
*In case you can't tell I am a complete newbie when it comes to all of this, and was caught off guard...
So, basically is it worth keeping the HD DVD player because I can get good use out of it, and the current HD DVD movies, and continue buying HD DVD movies that will still be viable 1-5 years from now?
Or should I return it because the movies will prove incompatible in the very near future, and use that $ towards getting a Blu Ray?
RC4
RC4
