Originally Posted by
aydu
I have heard nothing but horror stories about Directv's strategy of getting your credit card number and charging it for whatever they want. While Dish has the same contract requirements, I didn't feel that I was dealing with outright crooks.
These claims are usually greatly exaggerated. It does happen from time to time but it is usually pretty easy to fix. Most of the time this is caused by the customer either forgetting/refusing to send the receivers back when they are supposed to, however sometimes it is DirecTVs fault for not correctly getting the returned receivers checked back in to their system. If you make sure to keep the tracking information for the receivers that are sent back, then you can show that to DirecTV as proof that they were returned and they are usually pretty quick to refund the money to your card.
aydu
One advantage that Directv seems to have is in the whole house DVR concept. The install guys said that Direct uses existing house wiring for their install, so they have it easy compared to the work Dish installers have to do. The DVR interface apparently works through this single cable connection, making it easier to leverage one DVR throughout the house. Dish is behind in this area. Although I have multiple TVs, the DVR content is only usable on the one set I have it connected to. I can connect a 2nd set to the DVR, but only get SD output.
Whole Home DVR is great. I have had it for a couple years now (I beta tested it before it was widely available) and couldn't go without it anymore.
DirecTV will try to re-use existing cabling if possible. However they too must make sure the splitters in your home are rated high enough (3Ghz I believe) and the cable is good enough (they prefer RG6 with solid copper core, but I believe they can still use RG59 if it is in good shape). Otherwise they will rewire the house. Free install is running the wire on the outside of the house and drilling in through the exterior wall. If you want wall fishes to interior walls they will charge extra.
Old splitters will not "burn out" they will just block the signal so it is unusable.
As far as your questions about Dish's price lock-in, the way I understand it is they have promised not to raise package prices on you, but they can still raise the fees that they charge for DVR/receiver rental, and stuff like that. So they can theoretically still raise your bill.
