I purchased this beauty about 5 weeks ago and did my basic DVE DVD calibration (I am using a Samsung BDP1400 for playback w/DVD's upconverted to 1080p), but I had some "odd" results. I don't know if this is an issue with going from a CRT based unit to DLP, if the process of upconverting is the problem, or if this is just a quirk of using the Samsung user menu controls. The picture is better, but I think it could be much better (not that it is in any way bad now!).
Anyway, to my point. I have been lurking around here for quite some time (off and on for a couple years) and being a DIY geek decided to try my hand at self-calibration. I managed to find a pretty good deal on a DTP94 and I thought I would use HCFR. I have the service menu code for my set, so I think I'm ready to give it a try, but I haven't been able to find any reasonable length threads that might help me with my particular setup. Most seem geared toward FP's or CRT RP's. Then again, I don't have the patience to slog through some of the VERY long threads on this topic.
I would appreciate any help I can get with this.
Best regards,
Scott
Best regards,
Scott
