Herve,
The HP hp s3330f sounds like a winner! Could you describe how to use the PVR recordings:
- How do you program the unit to record; is it menu driven where it can download a list of shows (like Tivo) or do you set the start/stop time?
- Can it do recurring events (i.e.: M, 8 to 9 for 6 weeks)?
- All recordings match the resolution of the original material (so 1080i is recorded 1080i)?
- Are you using it for over-the-airwaves recording? If so, is the tuners sensitivity good?
- Can it go from hibernation mode to wake to complete your recording then hibernate again? Can you tell I'm green?
- How do you like the remote? Does it work well enough to be able to get most of your media w/o using a mouse/keyboard?
I'm just about ready to plunk down the green for this unit! I think the price is pretty much the same everywhere (local and mail order); I know this is new, but are there any sales for this?
Thanks for your descriptions!
