AVS › AVS Forum › Video Components › Home Theater Computers › HP Pavilion Slimline s3330f, is it a good prebuilt htpc?
HP Pavilion Slimline s3330f, is it a good prebuilt htpc? - Page 12
post #331 of 336
i can't remember exactly how to get it out it's been awhile since i upgraded my memory, i had to go to the documentation on hp site but i think it slides to the front. go their sit it tells u how to get it out.
post #332 of 336
thanks, yeah I almost all optical drive slide out the front, I will get on HP's webiste, thanks again.
post #333 of 336
I am interested in buying the s3330f from a guy on craigslist but he says it doesn't have a Blu-Ray/HD DVD player. I thought all s3330f's had that drive? Is that right? Also if it doesn't have Blu-Ray and is 6 mo old but in "perfect condition", is $300 a good deal for it?
post #334 of 336
Blu-Ray was an option, not an automatic thing. Depending upon the CPU, you'll likely need an upgraded video card (low-profile nvidia 8400gs/9300/9400/9500 will suffice), as the onboard vga won't cut it for blu-ray. Ask whether it uses built-in video from the motherboard or a plug-in video card. If you can get a copy of the receipt for warranty purposes, I'd call that a decent deal. My local Frys had a s3600 for $300 + tax before xmas. I got two Intel E2200 based ones with 2gb RAM and 500GB for $300 shipped, but those were refurbished with only a 90-day warranty.
post #335 of 336
Thanks for the reply. I hope I don't have to upgrade the video card, I will have to ask him tomorrow what it has. These are the specs I do know: AMD 64 X2 2.8ghz, 2gb RAM, 500gb HD, TV Tuner, and he has obviously reformatted the HD and reinstalled Vista Premium. How long are HP warranties normally?
post #336 of 336
One year. The TV tuner will take up the PCI slot, leaving you with one PCI-Express slot. That's the one you'd use to plop in a video card. You can get a low-profile card for about $30.
ALternately, if you wanted something new, I saw a s3700f at office depot for $350 + tax after rebate. Similarly equipped, but no tv tuner and only 320gb.
http://www.officedepot.com/catalog/t...archTxt=825845
