I am in the process of finishing the home theater. My wife has done a nice job at the decorating plans but we are trying to figure out whether we will need sound absorbing panels.
A few details - the room is roughly square at 22 by 20 although one rear corner is chopped off at about a 45 angle. At the first reflection point side wall, we have a window so my wife is planning floor to ceiling curtains about 3ft wide. We'll do this on both sides for decorative purposes although there is no window on the other wall. At the second reflection point side wall we will have the same curtain on one side. THe opposite side is where the 45 degree notch is in the room so I was going to do nothing. THe floor is carpeted, the walls and ceiling are wall board.
Do you think i need sound absorbing panels in addition to the curtains? If yes, can I put them behind the curtains or will they not do anything. I imagine the curtain material will be a critical piece. THey won't be heavy, thick material - think regular cotton/polyester maybe a bit thicker than a dress shirt you might wear. Do I need any other sound absorbing panels and where? I have a 7.1 setup.
thanks
rick
thanks
rick
